20 Most Recent
Zenith XBV713 Questions & Answers
Unit not responding in any way.
Hi Beverly Neal,
At this point, It isn't worthy to get this VCR fixed since the manufacturers stopped their production in 2016 or earlier so It might be hard to find parts to fix it or to expensive to get it fixed.
I need a region code
OK... now some DVDs cannot be hacked / or unlocked for regions BUT
go to e-Bay and search for dvd region unlock code... there are some there BUT go into a couple to see if they will let you contact them FIRST to see if yours can be unlocked BEFORE YOU BUY.
Good luck...
Code free dvd player XBV713
The
Hello!
It seems there is no region hack yet available for the Zenith XBV713 model.
However, for the model XBV613 there is....It might worthy to try.
Here's the procedure:
1. Create a non-empty file called
LG36868.IMG (For example, use a text editor to create a file and save a
file. Then rename the file to LG36868.IMG. Make sure the file
extension is .img)
2. Burn the LG36868.IMG file to a blank data CD (not a DVD).
3. Insert the CD in your DVD Player. Press Play.
4. The region management menu will appear.
5. Use the remote control and enter '0' to set the unit to region
free.
6. Press the pause on the remote.
7. Eject the disc.
Note: When I reached step step 6 the display on the front of the
DVD player said "error", but the hack worked anyway.
Please your help.
I will
i can provide you a manual and cannopt prode you the software.
here is the manual .just go to the link below.
http://animalscience.ucdavis.edu/help/Classroom_Technology/162B_Meatlab/PDF/Zenith%20XBV713%20DVD%20Player%20VCR%20Combo%20Manual.pdf
12/24/2010 10:22:38 AM •
Zenith XBV713
Answered
on Dec 24, 2010
The VCR eats tapes. Opened it up and see a thin
A dirty VCR will do this and usually has little to do with loose parts.
If you are not comfortable doing the cleaning take it to a qualified repair shop.
In this day and age it is most definately cheaper to replace the unit.
Good luck
