20 Most Recent
iRiver clix 2nd generation MP3 Player Questions & Answers
My iriver does not power
I did some research on your issue and it appears that several other people have had issues with the iriver product not powering on and have gone to the following web site and had the mother board replaced. they all report that after getting the products back; they had no futher issues with the irivers they own
http://www.iriver.eu.com/rma.html
I attempted to accept your instant chat but someone got there quicker i guess. Oh well, I hope this helps you out any ways. CHEERS :)
I would like to ask the problem of my iriver clix
If it do not power up at all ..check the battery ..cause it may have connection problems ...if it opens but freezing on start ..look for the reset button ..and reset it ..This is a button hidden in a hole and need to be pressed with the stylus or with a sharp object ..and the unit has to be powered and on when you do it (even if it is in freezing position )
In the first case..no power at all ..you will probably need a new battery cause this one it is either corrupted or lost the ability to store the power ...It might power with the ac charger inserted so its worth a try ..
My music won't delete
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please rate me,
Thank You
Won't Turn On
click the reset button....i was having this same problem and i clicked the reset button and it started working again...
Iriver plus 3 software issue
i have vista and had the same issue even though plus 3 worked the first time i installed it (might be an issue with the safely remove hardware icon not available most of the time in vista), so now i use windows media player to sync to the device and works fine
