20 Most Recent
La Marzocco FB70 Questions & Answers
How do i set/calibrate the shots on my la marzocco fb70?
Depending on model (yours might have a toggle switch to set it to program mode), hold down the continuous/stop button on the left pad all the lights will be lit after 5-8 secs, then push button to program get volume then push button again or stop button.
Water at group heads needs be hotter
Check the top of the coffee boiler you will find the thermostat for setting the temp, you will probably have to remove the front panel to access it.
Calibration (2 group head la marzocco)
press and hold the swirl button on the first group (far left) lights will blink. press the button you wish to program, once you reach the amount of espresso you wish to give press the button again then it will be stored into memori do this to the rest of the buttons on the first key pad. after you finished the first group the computer will automatically transfer the same programing to the second group. Good uck
Commercial espresso machine
Sounds like the safety thermostats on the machine is tripping because the machine is overheating or the circuit breaker is tripping because machine needs more amperage.
The pressure is more the
Sounds like the the tube that connects to the pressure stat is blocked or the pressure stat is damaged and needs to be replaced.
3 group Linea
First the breaker
Is the machine on a 20Amp or 30Amp circuit. If 20 then change it to a 30 amp circuit. That should provide enough power for the machine. in some units there is a reset button in the broiler chamber.but if its not in your machine.then there is no other reset button.the problem indicates that its fault in the control panel of the machine.either its a power problem or the fault in the control panel.the machine control panel has to be checked and replaced.
check out.keep updated.thanks.
No steam will come out
Make sure you have the control knob turned the whole way to where it needs to be. You should do the steaming before the brewing, so you have enough water to make the steam. If this isn't the issue, run a mix of 1/2 water, 1/2 white vinegar through the machine. Run 2 or 3 more cycles of plain water to rinse the vinegar out. If the unit was clogged, this will melt the residue away.
La Marzocco espresso machine troubleshooting
Where is the steam coming from the small valve on the top or the big tall one? If it is the tall one then the problem is in the block electrical box(pressure stat) on the left above the element, that may be stuck and not telling the machine that it has enough pressure turn off the elements.
Customer service phone number
Hi there!
You can find all details for La Marzocco
Here
There is also an email form for any parts you require and other information there too.
If this works for you. Please spare a moment to rate as Fixya! thanks
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
