20 Most Recent
Whirlpool GS2SHAXM Side by Side Refrigerator Questions & Answers
Need to reattach door hndle
yes i need to fix the doors handle their are loose and i want to tight it up, but i don´t know how to do it
4/1/2011 2:14:00 AM •
Whirlpool...
Answered
on Apr 01, 2011
Need to disassemble a Sears Kenmore 106.57372700
Sounds like the IM heater stuck on that's the only thing that would have melted liner. Check the optics open the freezer door and push the flapper on the right side back and look for a green light if it's on solid optics are ok if there is no light or flashing replace the emitter and receiver
2/17/2010 3:27:23 AM •
Whirlpool...
Answered
on Feb 17, 2010
Whirpool fridge won't make ice
a loss of water supply to the refrig could cause this problem. check the fill tube that supplies water to the icemaker (this is the tube that omes into the rear of the icemaker) i think you will find it is frozen up. you can clear this out wiht a hair dryer. I just looked at a diagram for the model number you provided and the fill tube is the black tube that comes into the fill cup on the far right hand side of the icemaker. you will have to raise the icemaker door to see it. but heating this and clearing the ice will fix it thanks peyton
3/2/2009 1:05:00 PM •
Whirlpool...
Answered
on Mar 02, 2009
I have a whirlpool WRF40 IX all refrigerator. The ...
WHIRLPOOL WRF40 Solution to this problem!!! very easy ----I assume you have a problem with the control board switching on and of erratic when you pass setting 3 on the LED display, the designers of this fridge left the calculator at home that day, ask a technician to replace the Resistors 5, 6 & 7 (330 OHM 1/4 watt) on your electronic control board with 680 OHM 1/4 watt. This would solve the problems with this board, the LEDs will not be as bright as they were but still highly visible. Questions?
[email protected]
10/7/2023 6:12:17 AM •
Whirlpool...
Answered
on Oct 07, 2023
Whirlpool refrigerator is not getting cold but freezer is freezing. Can someone help, please?
As the freezer is working you can probably discount that the reason is low refrigerant gas. The other reasons would be that the fridge circulation fan has failed.
or
The channel that directs cold air from the freezer is blocked with ice at the rear of the freezer. It happened to my GE and was caused by a failed defrost timer that was icing up the evaporator coils at the back of the freezer.
A service call lasts about an hour including melting the ice with a heat gun..
10/3/2023 2:45:18 AM •
Whirlpool...
Answered
on Oct 03, 2023
