20 Most Recent Behringer Used Ultra-curve Pro Dsp8024 Questions & Answers
Behringer ha 8000 transformer replacement help.
Toroid Transformer is used in power supply not with headphones out. Headphones out are directly connected with headphone amplifier IC. (Note that the difference in 4700 and 8000 is number of channels. Rest of the circuit diagram is same). Behringer HA 4700 PowerPlay Pro-XL ' SynthXL - FREE Service Manual
12/19/2023 2:37:58 PM • Behringer Audio... • Answered on Dec 19, 2023
Behringer PMP3000 audio mixer: the effects are stuck on 90. Cannot select any other effect program.
When a heavy item is dropped onto the top of a control, it can break internally. I would check the encoder switch is working correctly, if not, replace if needed.
12/7/2023 7:40:55 AM • Behringer Audio... • Answered on Dec 07, 2023
My behringer pmp1680 has no output to speakers
Check the routing and toggle the buttons. It may be a tarnished connection.
10/8/2023 7:06:08 PM • Behringer Audio... • Answered on Oct 08, 2023
Please help! Behringer KX1200 master volume stops past 4 and no lines work just fx return
Also how do I reconnect the fan? It sounds like you may have a broken potentiometer (aka volume knob) for the master volume control. If that is the case, you would need to replace it with a new one (or take it to an electronics technician to diagnose and repair). Regarding the fan disconnection, this likely isn't causing your issue but you would still want to reconnect it as it keeps your amplifier cool while in use. Reconnecting is fairly straightforward - all fans have 2 or 3 wires that connect to corresponding terminals on the amp. Just make sure you don't mix up which wire is positive and negative, and make sure they are connected firmly and securely.
2/23/2023 12:47:59 PM • Behringer Audio... • Answered on Feb 23, 2023
No sound from mxl 990 condenser mic
I would order new cable price = quality. CBI cables with neutrik connectors.
2/7/2023 7:29:21 PM • Behringer Audio... • Answered on Feb 07, 2023
Behringer EP1500 amp does not produce full loudnes
Hi, Please test the loudness of your device with a third-party decibel meter. This will give you a clear measure of whether the loudness of your device is changing with increase in volume. It could be that your surroundings are absorbing the increased sound. Thank you.
10/11/2022 12:40:04 AM • Behringer Audio... • Answered on Oct 11, 2022
I have a behringer epa 300. It has a problem. it tends to reduce power considerably when I use it outdoors.
is there a noise reduction setting thats on
9/25/2022 7:36:19 AM • Behringer Audio... • Answered on Sep 25, 2022
Behringer Europower PMP 1280S Powered Mixer
Question edited to spelling or 'Europower'. I am a but confused by the question but here is the manual dealing with a monitor. Page 5, 10, and 11. https://www.manualslib.com/manual/214306/Behringer-Europower-Pmp1280s.html?page=5&term=monitor&selected=1#manual ..
7/16/2022 2:20:44 PM • Behringer Audio... • Answered on Jul 16, 2022
2answers
How to get 5.1 sound. to an external audio card?
The channels are setup according to the model. If you have stereo (2 channel L/R) then you cannot get 5 channels out of it. To do this you need a card that is 5.1. If your card IS 5.1, then i would enable the channels in the audio mixer for the card.
2/23/2022 7:03:32 PM • Behringer Audio... • Answered on Feb 23, 2022
Behringer VQ1500D - no sound
Check your cabling first.
11/7/2021 5:12:31 PM • Behringer Audio... • Answered on Nov 07, 2021
KXD15 keyboard combo. How can I get a schematic diagram?
Contact Behringer directly with your request.
3/15/2021 3:11:38 PM • Behringer Audio... • Answered on Mar 15, 2021
Hi! I have a Behringer B1800d PRO active subwoofer which is acting up. At first it just stopped putting out any sound at all except for a “click” or a “pop” every 5 sec. interval or so. But lately it doesn’t even turn on anymore. When it has been off for a while and you turn it on, the blue power LED is lighted up for like half a second then it completely dies again. I know the description may be a bit vague but I don’t really know how to explain it. What is the best way to trouble shoot this? Also in case that I can’t fix it, would it be possible to turn in the amplifier ONLY to a repair shop, without the actual subwoofer housing and the element? Thanks a lot!
The issue is the power supply inside. There are most likely bad capacitors inside. You can tell in SOME instances by looking at them. They look like miniature can. If they are bulging on the tops or sides or they are leaking a brown substance out of the bottom, they have failed. Please note that they can also fail and show no signs of failure. For those cases you need to get a meter to test them. They are not cheap meters. If you cannot solder or perform other electronic repair procedures, it would be better to send it out for repairs.
10/30/2020 8:32:07 PM • Behringer Audio... • Answered on Oct 30, 2020
All lights flashing no sound coming out but sound in earphones whats wrong with it its a djx750 behringer
It's finished. The wires connected to the sound is most important.
9/11/2020 2:01:14 PM • Behringer Audio... • Answered on Sep 11, 2020
2answers
I have a Behringer pmp1280s. It was working fine 12 months ago. I got it out again today. Everything lights up fuses are fine. level lights work. No sound out of speaker outputs
I doubt that there is a problem with the unit. Usually people have problems with their cables or the speakon plugs themselves. Unscrew the connector that is used on both ends and double-check their connections. Sometimes the screws that hold the heavy gauge wire in place, come loose. Also make sure that they are in the right places. Sometimes you have 4 connections. Make sure they are in +1 and -1 connections. Every once in a while you'll find a quirk unit that requires you to use +2 and -2 instead. Look at the back of the amp. It should tell you which numbers it uses. Make sure you check the same thing on the speaker end also. If you have a meter or continuity checker, use it to make sure it's wired right. This is a professional piece of equipment. They don't go bad easily. Make sure you tighten those connections real good and that you pay close attention to the engraved numbers on the speakon connectors. (That is if they are quality connectors. The cheap ones may NOT tell you the numbering or the phase, ((+ or -)). Hint: The negative one is always closest to the outside of the plug. You'll have to study it to understand that. The screw terminals on the inside have 'walls' on both sides of it. Those are the + connections. Also, check the switches on the front. You may have one of the switches in the wrong position or setting. Also if you're using phantom powered mics, you have to turn the phantom power on or else they will not work. Hope this helps.
10/5/2019 3:50:28 AM • Behringer Audio... • Answered on Oct 05, 2019
Hi ther, I have behringer B112D powered speaker and when it powers up seems to be looking for Bluetooth instead of finding normal power. Lights flash constantly but no connect when plugged into desk
Do you have the mics and dongle system accessories? Your question does not state if you have them or not. If you do have these accessories, and you only want to use the wired option, remove the dongle so it stops searching for the microphones. Hope this helps.
6/27/2019 10:02:57 PM • Behringer Audio... • Answered on Jun 27, 2019
Behringer EUROPOWER PMP5000. using vocals with effects it produced what I call white noise. shut it down, and it worked fine, later it did it again. I turned down all effects and it was fine.
Hello Doug, obviously for what you are saying, you would have a problem in the effects processor of your Behringer, I suggest you use an external processor to corroborate that the problem is not in the shipping bar, or in the allocation of returns If you have technical knowledge, disarm the mixer and control the internal connections of the effects processor, see if there are no loose solders I sent you the link to download the circuits of your PMP5000 If you do not find the origin of the fault, look for a specialized technical service I hope you can solve the problem Greetings Franco Dosil Hola Doug, evidentemente por lo que comentas, tendr?as un problema en el procesador de efectos de tu Behringer, te sugiero que utilices un procesador externo para corroborar que el problema no esta en la barra de env?os, ni en la asignaci?n de retornos Si tienes conocimientos t?cnicos, desarma el mixer y controla las conexiones internad del procesador de efectos, observa si no tiene soldaduras flojas Te env?o el link para descargar los circuitos de tu PMP5000 Sino encuentras el origen de la falla, busca un servicio t?cnico especializado Espero puedas resolver el problema Saludos Franco Dosil https://www.electronica-pt.com/esquema/audio/behringer-audio/behringer-europower-pmh5000-rev-d-15967
4/30/2019 3:25:13 PM • Behringer Audio... • Answered on Apr 30, 2019
Behringer Used Ultra-curve Pro Dsp8024 Logo
2 questions posted
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Behringer Audio Players & Recorders
Most Popular Question
change battery in behringer ultra curve
  • Audio Players & Recorders
