20 Most Recent
RCA JET S2002 MP3 Player Questions & Answers
Well i had my RCA
Click on the bubble and it will take you through the process of resetting the player
I have a RCA Jet
Welcome to Fixya. Can you please provide the model of your RCA mp3 player so that we can provide you a solution to your issue.
Thanks
How do i delete and
There should be a program included with the mp3 player. If not, windows media player should do the trick. Plug it in and open up windows media player.
ERROR! REFORMAT EXTERNAL MEDIA WITH SIGMATEL
See other solutions posted here about downloading new firmware. Included is holding down the play button when you turn it on and connect it. Click the box to reformat the disc and install ver 1.5 or later of firmware. It wipes the drive but it works. Good luck!
My jet, when i sync
You have to plug the mp3 player into your pc and then click on format. The data inside may be corrupted and that is the reason why you are receiving the error. After the format, you can load music again and enjoy listening to your songs.
When first plugged in it
time to buy a new one something has gone wrong with the processor by the sound of it so its cheaper to buy a new one
It froze and it wont turn off what do i do?
Greetings Williambr123,
There is no technical way of fixing this. My recommendation to you, is to let it be until the battery dies. This usually only takes a day at the most. Once dead, fully recharge the MP3 player. It should be good as new. If you have any further concerns or questions, feel free to contact me. Thank you for using FixYa. =) Please rate.
How do you remove all
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
BE CAREFUL and do not delete files needed to operate your MP3 player.
Please rate me
I have a problem formatting my RCA ip01 mp3
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Como puedo formatear mi mp3 por que los archivos
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
#3
#4
#5
#6
With A USB , CELLPHONE , Camera The SameThing
Mp3 palyer will not turn on.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Why when i turn my
hi, try to format the mp3 first, if doesnot works, reset the mp3 to factory settings , if you do that you loose all datas that you put in the mp3
