20 Most Recent
ViewSonic VA1703wb Monitor Questions & Answers
Dra.comI was running out of
Use what works and stop updating unless you absolutely have to. That procedure most of the time creates more issues than you can imagine and often renders a machine useless! If not broken, leave it alone!!!!!!!!!!!!!!!!!!!!
8/28/2017 1:49:34 PM •
ViewSonic...
Answered
on Aug 28, 2017
Fading colour
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
4/9/2014 7:09:17 PM •
ViewSonic...
Answered
on Apr 09, 2014
SCREEN RESOLUTION CHANGES IT SELF
check out for the latest update of display driver .
also refer to user manuals of your monitor/display adaptor/ motherboard { may be a compatablty issue with the os}
and make sure that your pc is free of viruses
9/4/2013 3:55:41 PM •
ViewSonic...
Answered
on Sep 04, 2013
Blue Screen of Death
r u sure the monitor is causing the blue screen of death?
I would try another monitor to verify.
12/18/2012 2:37:21 AM •
ViewSonic...
Answered
on Dec 18, 2012
Va1703 wb blinking problem
Hello,That is a sure indication of a failure in the power supply board. The problem is that Viewsonic used two different power supply boards in the va1703wb model. If you want to do the repair yourself you should be able to. If you can open the unit and send a picture of the power supply board to us at
[email protected] we would be glad to show you what parts need to be replaced to rebuild the board and get it back up and running.
2/15/2012 9:21:05 PM •
ViewSonic...
Answered
on Feb 15, 2012
1440*900 resolution is not coming
Your going to love this. Open control panel, open display. Click the settings tab. Click Advanced. Click the Monitor tab. Remove the check mark from "hide modes". Click the drop down menu & set it to 75 hertz. Click Apply & than ok. You are now back to the Settings window. At Screen resolution move the slide bar to more. Pick what you want. Again click Apply & than ok. Bingo there you are! Have a nice day.
please vote...
3/29/2011 11:11:58 AM •
ViewSonic...
Answered
on Mar 29, 2011
Monitor was alternating dim/bright, after a couple
Ok, you need to check the DC voltages on those four caps with the monitor in the OFF mode, do not turn on the monitor so the power supply will be running without the load (the power supply is running the minute the monitor is plugged into the outlet), you can use 12v car bulb such as 1157 as a load, the output voltage in the inverter should be around 12vdc with load, if it checked out OK, then the next step will be the inverter circuits, you will need to the test lamp to find out if the inverter is OK or if you have the bad lamps. The diode you replace is more likely to be SCHOTTKY DIODE for high speed switching power supply, regular diode will not work.
PM me if you want the service manual:
[email protected]
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
2/12/2011 2:15:12 AM •
ViewSonic...
Answered
on Feb 12, 2011
Had a problem in my lcd monitor, the innner
your authorized dealer in guwahati is
ACCEL FRONTLINE SERVICES (P) LIMITED (Mr. MOHAMMAD SHAARIQ )
Md. Tayabulla Road
Dighali Pukhuri East
Near Ambikagiri Library
GUWAHATI-78100
Contact number : 0361-2606592 / 27933973
12/7/2010 12:21:57 PM •
ViewSonic...
Answered
on Dec 07, 2010
