20 Most Recent
Technical Pro RX-B113 Integrated Amplifier, 1500 Watts Peak Power, Manual FM Tuning, 350w x2 Main output power, 100w Central output power, 100w x2 Surround output power, RCA 3 audio sources Inputs, Dual 10 band equalizers with individual LED indicators, iPod / MP3 Questions & Answers
I cannot bring up the volume to pass 20 if i bring it up higher it shuts off
Check that the speakers are the same impedance as the amplifier is rated for and that the speaker wires or connections are not shorted. It sounds like you are trying to drive 4 ohm speakers with an amp that is rated for 8 ohms - it will work at low volumes, but will overheat and shut off if you try to drive it too hard (higher volumes)
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
