20 Most Recent D-Link DKVM-2K 2-port KVM Switch Questions & Answers
As it stands on its own, no. You would need either a USB adapter to match either the keyboard or mouse port on the KVM. Another solution might possibly to get USB Hub to attach. Without physically testing it myself, I am not sure if it would work, but it is possible.
D-Link DKVM-2K... | Answered on May 02, 2011
You can plug them both up to the projector and switch inputs on the projector probably. I also see no reason why the KVM switch shouldn't work.
D-Link DKVM-2K... | Answered on Jul 20, 2010
the way the kvm switches works is you have your mouse/keyboard and monitor plugged into the switch then you have the cables connecting to where you would have your mouse/keyboard on your pc, youll be using the same keyboard/mouse and monitor to run 2 pc's. there will be rather a switch to move between the pc's or like the 1 i use i have tp press ctrl the number 2 twice.
D-Link DKVM-2K... | Answered on May 23, 2009
once you have switched pc you will need to re-sync the wireless keyboard and mouse with the new pc, because although you have switched pc the keyboard and mouse do not know this. there should be a reset/resync button on the bottom of both the keyboard and mouse
D-Link DKVM-2K... | Answered on Mar 24, 2009
That's strange...a suggestion (long shot) you can check out....some keyboards come with software that allows you to remap keys...possible I suppose that the n key was remapped to something else... Good luck
D-Link DKVM-2K... | Answered on Aug 28, 2007
access violation in module Uimain.exe at address oo6F6AB6
read address 000002EC
Computers &... | Answered on Feb 13, 2020
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
D-Link Computers... | Answered on Dec 19, 2019
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
D-Link Computers... | Answered on Dec 12, 2019
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
D-Link Computers... | Answered on Dec 04, 2019
You can get best d-link router support phone number at Toll Free Number ( 1-877-769-0969 ). D-link router Tech Support number ( 1-877-769-0969 )
D-Link Computers... | Answered on Nov 12, 2019
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
D-Link Computers... | Answered on Nov 11, 2019
no it wasnt THIS IS A COLLECTIVE PHONE LISTING OF ALL THE SPAMMERS HERE ON FIXYA. WE SUGGEST YOU DONT CALL ANY OF THEM UNLESS YOU KNOW WHAT YOU ARE DOING !! 1-85O-8I2-4OO9 1-8OO-8O3-1O69 1-888-499-5520 1-877-769-0969 1-888-499-5520 1-8OO-828-O294 888-348-1833 1-888-444-6538 1-855-616-7697 l-855-892-OO6O 1-888-570-9791 1-855-26O-OO64 1-855-536-5666 1-844-24O-9111 1-8OO-55O-5195 1-845-481-1722 1-855-616-7697 1-844-819-3382 1-855-221-4867 1-845-481-1722
1-800-871-6508 IF YOU KNOW WHAT YOU ARE DOING HAVE SOME FUN WITH THESE LOSERS.. CARRY ON
D-Link Computers... | Answered on Oct 26, 2019
CURRY CURRY ALL FREE CALL TODAY FOR FREE INDIAN CURRY RECIPES, TRAVEL AND WEATHER INFORMATION AND TIPS...ALL FREE NEVER ANY CHARGES +1-85O-8I2-4OO9.{+1'8OO-8O3^1O69 {1;888;499:5520 1~877~769~0969 1;888-499-5520
D-Link Computers... | Answered on Oct 19, 2019
go to dos prompt in a windows pc and type in ipconfig and press the enter key to find the default gateway address
it might be 10.0.0.1 or 192.168.0.1 these are the most common. Type the ip address into internet browser to log into the gateway router. There will be an admin user name and admin password. It might be the default or it might be written hopefully on the router case/
try
Username: cusadmin Password: password IP Address: 192.168.0.1 http://www.cleancss.com/router-default/SMC/SMC8014WG
if you get into it look up wi fi security to find out the wep key or wpa key
D-Link Computers... | Answered on Aug 23, 2019
Enter http://192.168.0.50 in the address field.
By default, Admin will be the User Name . Leave the password blank.
If you still can not access the web-based configuration utility see the troubleshooting guide on page 48 of the manual located at the below web link.Good luck!
http://www.dlink.com/-/media/Consumer_Products/DHP/DHP%20W310AV/Manual/DHPW310AVA1Manualv100WW.pdf
D-Link Computers... | Answered on Aug 22, 2019
At D-link, we understand the necessity of 24/7 need for an internet connection to connect you with the outside world along with providing you with optimum results as well. So, if you are facing any technical issues in your router and unable to solve it by yourself then with the tech support you can ask our experts. We will provide you Toll-Free Dlink Support Number Australia +1 888 597 3962 and online live chat so that you can reach us any moment according to your convenience.
The well-experienced and highly motivated technical teams with their years of experience at D'link Tech Support will patiently listen to your issue and provide you with an efficient solution. You can contact our specialists at the provided number and our customer care unit will give you the necessary assistance to resolve your issue. Our customer care number is always there to take care of all your Internet-related issues and will provide you with the best available solution to permanently resolve the issue.
We provide a friendly environment and take care of each complaint and feedback to provide better services to our clients. The Toll-free Dlink Helpline Number Australia +1 888 597 3962 and help centers are available 24/7 to assist our customers and free you from your distress of the web connection of the modem and the router. At Dlink, each customer is like a member of our big family and we love to get feedback from them. So, whatever be the need we are there to serve you the best we can.
For any kind of technical help during the process contact, Router Technical Support team to get an instant solution. They are available 24/7. Call Now ?+1 888 597 3962 for any Support.
More Info - https://www.quickhelps.co/phone-number/d-link/
D-Link Computers... | Answered on Jul 22, 2019
Hi! this is Alex Walker expert to help you for this issue call me on +1(518)348-9393 I will be glad to assist you Thank You
D-Link Computers... | Answered on Jul 18, 2019
D-Link DKVM-2K 2-port KVM Switch Logo
Popular Tags
15 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
possible use
  • Computers & Internet
