20 Most Recent
Toshiba Tecra M2 P-M 1.7Ghz, 512MB, 60GB, CD/DVD, 10/100PTM20U-3PU6X7Z PC Notebook Questions & Answers
Video Controller for Tecra M2
download the drivers here
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=856523&moid=555698&BV_SessionID=@@@@0479891764.1177854602@@@@&BV_EngineID=cccfaddkklfiidjcgfkceghdgngdgnn.0&ct=DL
Ergsf
> ergsf
Replace the keyboard on your computer, because the current keyboard is not working correctly.
I got a tecra m2
Pre-fetch the drivers from Toshiba:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
If you have a flash drive or a usb hard drive of any type, stick the drivers on a flash drive or USB HDD ahead of time. Then do a clean install of XP onto the hard drive, then hook up the flash/usb drive and install the drivers from there.
I have downloaded every driver from toshiba and
This could be very time consuming..
Remove this driver and rescan - let window auto detect and install driver - network install if needed..
Make sure you have Service pack 3 installed..
There couple be a patch fix that would prevent you from loading your drivers correctly.
If this doesn't work!!
The restoration disks would be the most simplest way of restoring the laptop.
Search by serial Number @
Toshiba.comMost computer companies only charge $20-$40 us dollars - free shipping..(restoration disk)
Thank you for contacting fixya.com
No video on screen.
Apparently the problem presented isn't something that a QUICKY or Work-Around will solve. I suggest you take it to a qualified technician and have him look at it. My answer is based on the information you have provided about how it was handed to you!
Some keys on my keyboard dont work
The keys may have dirt and debris beneath them or could be damaged.
Go to Start, select Control Panel and then type keyboard in the search box on the upper right side. A new window will open; click on Keyboard and select either option from the menu to verify the functionality of your keyboard...
Mi tecra does not
Please try to check if your network adapter driver is installed in your system. if it is nit then please install its driver to be able to used it.
Thanks
Where do i find Tecra Lan drivers, it has been 4 days without Internet
dear a.
try here:
http://www.gzrcw.net/drivers/toshiba/Tecra/drivers_1200.html
or toshiba homepage:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=835450&rpn=PTM20U&modelFilter=M2-S7302ST&selCategory=3&selFamily=1073768664
this will exactly meet your needs.
paste and copy the links. good luck
Built in hdd error
remove the hdd and attach to desktop .
right click in my computer and run check disk in tools section in drive properties
Toshiba tecra s3 supervisor password reset
1. try with clear cmos and remove AC adapter and main battery.
2. also pls try to remove the code with password re set web site or password remove tool in hiran boot cd
Toshiba tecra no image
need more information to determine the fault. but you can remove the battery and pls plug ac adapter and also re seat the RAM. power on and test
