20 Most Recent
Samsung SGH-E760 Cellular Phone Questions & Answers
I have Samsung SGH-E760 cellphone.
My
Any good phone service guy will either be able to fix that, or to explain why it can't be fixed.
How many phone service guys are there in your town, please?
I have problem in installing game on my phone
YOUR PHONE IS A JAVA ENABLED PHONE.
IT SUPPORTS .JAR TYPE EXTENSION. IT MEANS IT WILL SUPPORT ONLY THOSE GAME WHOSE NAME ENDS WITH .JAR FOR EXAMPLE ASPHALT.JAR
GO TO WWW.MOBILE9.COM AND DOWNLOAD JAVA SOFTWERE FROM 176 x 220 RESOLUTION CATEGERY. AND INSTALL THEM. USE MOBILES DEFAULT BROWSER TO DOWNLOAD GAME.
INSTALLATION MAY TAKE SOME TIME SO DO'NT PANIC.
I want to delete Phonebook
do wish to delete the whole phonebook or one particular party...in any case go to the party you wish to delete choose/options/manage or delete and on to the next one...there is no mass deletion
Can't hear person on other end of phone but they
At the bottom of the phone, check to see if there is any thing stuck in the mic opening, if not and if you are not in a bad reception area, you will need a agent to replace the phones voice mic.
Hope this helps
Free unlock code for sgh-t528gsamsung sgh-t528g
Hapy New Year:ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
How to STOP your Samsung Note 9 from constantly pocket dialing
OMG I finally figured out WHY my note 9 was constantly pocket dialing people. I tried so many things. This is what finally fixed it. It is a gesture setting. Open up settings. go to advanced settings then gestures.. Turn off Direct Dial. Direct dial is a setting that makes your phone call someone that you have been texting when you hold the phone to your ear. What happens is when you put the phone in your pocket it thinks you are holding it to your ear.
Insert sim e1220
If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box.
Solution for samsung freeze phone
What is your SAMSUNG Model specify it correctly..You need to specify the current network and country it's locked now ..You can use UNFREEZE CODE to Unfreeze SAMSUNG Phone.You can get the Unfreeze code for samsung phones at
Theunlockarena.com/unlocking-services/rs13wp6/check whether Unfreeze service is available for your mobile's locked network and country ,if it's available you can get the unfreeze code here and unfreeze it.
