20 Most Recent
Nokia 1600 Cellular Phone Questions & Answers
I need a name and address from one number
You need a reverse lookup service, available from multiple suppliers on the web, just by googling with the phone number in the Google Search field, and which services will cost you $$$. So, shop around CAREFULLY. As in every other product category, some of these services are better than others, and some of these are pure SCAMS!
In Nokia 1600 type RH-64 i forgot security code and now cannot reset call timers, would you pls help?
Good Morning:You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Master Code request for Nokia 1650
You must enter Security Mastercode instead of lost/forgotten Security Code or Phone Lock code when phone asks for it.
your security master code is 6422320463
Don't have a PUK code
The PUK code is availlable from your service provider.
This is the Master Code for your phone;
IMEI: 355526015671865
Master Code: 5416001176
Nokia 1600 restore factory settings code
You can format your Nokia 1600 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.If it is not working try this code*#7370# in standby mode.
Security code nokia type RM 305 IMEI 354869023164742
Hello My Dear:defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Resetting Security Code nokia 1280
How to break security code
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered.
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
For mathyn IMEI 010972008260174 Mastercode 5255056051
For mc hot IMEI 359838011209921 Mastercode 1600246040
For Guest IMEI Type *#06# to get it. Mastercode ??????????
For emanuelgaby IMEI 354528013559796 Mastercode 7367245612
This is the code needed to reset the Security code, nothing else, and it’s for your phone only. You type in the security codes (any) until the phone request the Master code; when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
My cellphone have a security
If you dont want to risk your phone use unokia.com ( 9 € ) where all codes are supervised and verified by our qualified technical team. Remember that if you try more than 3 times your phones will be hardlocked and will be not possible to unlock remotely by code.
CODES:
#pw+394976522221470+1#
#pw+045503670357104+2#
#pw+812341440005242+3#
#pw+738950167621352+4#
#pw+114034447232531+5#
#pw+297245322554144+6#
