20 Most Recent
Nokia 6230i Cellular Phone Questions & Answers
Puk code
You can get the PUK from your mobile operator (the SIM must be under your name).
Security code
Hi, i can help you with a master code but you need to know something first.
1. if the wrong code has been entered more than 5 times then the phone is hard locked and can only be unlocked using flash lead and unlocking software.
so if you have not entered more than 5 wrong guesses then i can get a master code that resets the security code to what it was when new and it removes the security code untill you choose to use it again.
What you need to give me is your imei number this is found on back of phone under battery and looks like 123456/12/123456/1.
its 15 numbers long.
I need this code because every single phone has a set master code based on the imei number. i have the software to generate these codes as i worked for nokia for years so i can help you but let me know then i can assist you further ok.
Phone restricted
Do you want to remove the Network restricted error from your phone?
You can get restriction code for your Nokia 6230i phone from
SuperUnlockCodes.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.Using this code you can remove the Network restriction from your phone permanently.
Connection pc usb
This code is a hardware device error code..so this could mean that your device driver hasn't been installed properly on your computer or your computer is not seeing the necessary drivers for your phone.so this is how you resolve it ok: open device manager and
- To open Device Manager, click Start, click Search programs and files, and then type Device Manager. A list of available matching items appears above the search box; click Device Manager.
Device Manager opens with your computer name at the top and a list of
devices that are installed on your computer beneath your computer name.
Locate the malfunctioning device in the list of devices, right-click the device, and then click Uninstall. When a warning message appears that you are uninstalling a device from your system, click OK. Device manager uninstalls the device.
Right-click your computer name in Device Manager and click Scan for hardware changes. Device manager scans your system and automatically reinstall your device.
Right-click the device and click Properties. On the General tab of the device Properties dialog box, in Device status, you should see the message This device is working properly.
If the steps above do not resolve the problems with the
device, , use the taskbar icon to safely eject the
device, then unplug the device from the computer.If the device includes a
drivers disk, ensure that you have it handy to install the device
drivers; otherwise, Windows should automatically locate the correct
drivers and install them.
If you do not have a driver disk and Windows cannot
automatically detect the drivers, it means that your hardware
manufacturer has not uploaded the drivers for your device to Windows
Update. If this is the case, you must go to your device manufacturer web
site to download or request the most recent drivers for your device.
Nokia6230 whait lcd
(There are different types of problem that display white screen)Example 1. LCD (try by changing a new LCD)2. Patta (try by changing a new Patta)3. Software (Flashing)The best way is refer to the nearest mobile service centre for your problem.Thanks for using FixYaAll the Best!
Need unlock code for PCD model TXT8026C
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
