20 Most Recent
LG enV VX9900 Cellular Phone Questions & Answers
Env3 turning restarting?
Replace the battery with a NEW one. There is a good chance that will fix the issue. How old is the phone/battery?
When i go to dial a number from the touch
You must have stuffed your phone with too many things which makes it slower enough to make the keypad dissappear cus of low memory,. Try uninstalling unused apps and pictures videos and others, it it still persists, try downloading truecaller app from the play store and make it a default caller app. That will solve your problem. For that I'm sure. Thank you. Try that and get back to me.
So, my phone worked just
The problem can be either
> in your charging cable(I mean, any single point or in multiple point disconnections from wall charger to the plug in your phone.
> Your phones power socket is damaged.
In your case, 90 %,the 1st thing must be the problem. Get a new charger or a charging cable
Phone freezes whenever I press "End" key or the "Clear" button
Hey,
Thanks for nothing people. I figured it out myself. It turns out I had a miniSD card I had been using with my laptop in the phone and it was formatted in a different format that the phone didn't recognize (I use Linux on my laptop, and Linux uses different file formats then Windows). The different format must have caused the phone to freeze, because after I took the miniSD card out, the phone went back to working properly (unless smacking it on the table whenever it would freeze helped. lol jk jk). I hope this helps someone else who has trouble with a freezing eNV.
Adios Beeches,
-OP13
