20 Most Recent Motorola Mobility MOTOKRZR K1 Cellular Phone Questions & Answers
I believe you have a problem with the hinge of the flip where your wire that connects to the display opens up your screen. If you keep opening the flip and closing it slowly does the screen turn on and off??? If it does then you have a problem with the hinge like I said. If not then it could be just a software glitch where you need to reinstall the operating system.
Motorola... | Answered on Sep 24, 2017
If your handset does not support stereo music on blue tooth headset, then you can not hear music on blue tooth head set. However you are able to answer and make calls through blue tooth headset.
Motorola... | Answered on Dec 22, 2016
To Unlock the Motorola MotoKrzr K1 use the Unlock code,You need to specify which Country Network it Locked Now?
You can get the Unlock code here
http://www.wickedunlock.com/motorola-motokrzr-k1/rs11wp9/ and Unlock the Mobile from the Network Lock........
Motorola... | Answered on Nov 29, 2016
i believe k1 can handle a 1 GB micro sd card and
it will not cause you any trouble. above 1 gb? well, 2 gb, you may still use it but once you put it try to format it from your phone and not from computer, above 2 gb? well i guess, it will give you some pauses, lagging or hang during phone operation and don't forget to consult your phone specifications or manual for clear clarification.
good luck.
Motorola... | Answered on Oct 14, 2016
Another way of completely drying the phone is to put it in a bag with some rice, rice absorbs all moisture...
Motorola... | Answered on Mar 14, 2015
What is your question?
Motorola Support
Motorola... | Answered on Jan 29, 2015
In order to find your recent calls you can see the options from the manual of your phone: http://1.bp.blogspot.com/-hPi1XjKOZ40/UQ_YtT8FMuI/AAAAAAAAALM/dyZE_WVzQOg/s400/npb1-my-dog%2Btattoo_thumb%25255B1%25255D.jpg
Motorola... | Answered on Jul 17, 2014
Hi, you can find the users manual for your phone here
Motorola... | Answered on Jun 30, 2014
You need a driver for the phone to match the operating system. Contact the manufacturer if they have a driver so that the OS can recognize the phone and once it recognizes you have to go to the explorer and look for your phone as a device drive. Then from there copy the files. Let me know the OS you are using.
Motorola... | Answered on May 11, 2014
Use a computer. Computer gives you more flexible method to delete post that are unwanted. On a phone, function are limited. Try it out and post your finding here.
ubicacon de la memoria
Motorola... | Answered on Jan 13, 2014
Add the number to your agenda and call it whatever
Go to the contact again and tap on MENU
Enable the check mark on Reject All Calls
Motorola... | Answered on Dec 03, 2013
HI is your Motorola Krzr K1 phone is locked by network provider .Then you can easily fix it just by using sites like Mobile-Unlocker.com here they are rendering network unlock code for all mobile models at reliable cost ..You first verify that whether they are rendering code for your country and network provider .If yes then pay for it and unlock your phone .
Motorola... | Answered on Dec 02, 2013
no Arabic language in motorola
Motorola... | Answered on Sep 05, 2013
This means that the phone firmware is corrupt - you can try to reflash it using Motorola software update, but it might not work for a phone stuck in bootloader mode:
https://rsddownload.motorola.com/download/Motorola_Software_Update.exe
Motorola... | Answered on Aug 18, 2013
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
1,067 questions posted
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
MOTOKRZR Motorola Mobility
  • MOTOKRZR Motorola Mobility
Most Popular Question
phone went swim
  • Cell Phones
