HI,
Direct
Code Entry:
Find the code your
device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX
position, press and release AUX first and then press the device type to be
programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the
device on, press another button to test (volume control/power button).If it
does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps
to set remote without codes
Code
Search:
1. Turn on
the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX
programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using
the remote. If it does not function repeat steps 1 through 6
Thank you
454 questions posted
2,410 Questions
1,124 Questions
809 Questions
789 Questions
510 Questions
