20 Most Recent Nokia 3230 Cellular Phone Questions & Answers
You can get the smartmovie keygen from the following link
http://rs243.rapidshare.com/files/182019467/Smart_Movie_4.01_Cracked_And_100__Working__mobicreed.com_.zip
please rate this solution
Rnj VINODKUMAR
Nokia 3230... | Answered on Apr 07, 2019
sound like hardware issue
Nokia 3230... | Answered on Mar 17, 2018
along with the IMEI number please register a complaint to police that i had lost my phone..before doing this,contact the customer care of the mobile operator and tell them to block the usage of the sim..u can call from an alternate number..
Nokia 3230... | Answered on Sep 18, 2016
Try this, it might work for you. First remove any extra memory card and sim card inside your phone. After doing that, turn on your phone without those things. If there is message "Please insert sim card" then your good to go. Put your sim card back to your phone and then turn it on again. If it is successfully start then next thing to do is to insert the memory card back to your phone and then start up your phone again. But if in this stage your phone failed to start, then the memory card it causing the problem.
If all fails, then you need to format or hard reset your phone. Hold the * + 3 + green call key and then start up your phone while holding those buttons until you see a screen that shows formatting. Make sure you have enough battery power to do this procedure. You can plug the phone charger to make sure that everything will be okay.
Please leave comments for further instructions. Thanks..
Nokia 3230... | Answered on Jan 13, 2015
dear please download CORE PLAYER that is very good then smart movie player
Nokia 3230... | Answered on Aug 20, 2014
I hope this helps - I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!!!!!!!!
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
Your card should work fine now.....don't know why this has to be done, but it works!!!!!!!!!
Nokia 3230... | Answered on Aug 13, 2014
Every mobile phone have different Serial number EMEI. Dial #06#
Nokia 3230... | Answered on Jun 07, 2014
Please contact your mobile provider for any/all activation issues.
Thanks,
Dish Guy
Nokia 3230... | Answered on May 19, 2014
In all honesty Opera browser is moderately outdated. My personal suggestion to you is to deinstall Opera and replace it with Google chrome. If this does not correct your problem, please ensure your device is properly connected to the internet. (I.e WiFi, or cellular data)
Thanks,
Dish Guy
to connect to the internet & to send & receive mms messages you must activate the GPRS first from your network provider ...The best thing you can do is to contact the customer care of your network provider and ask for the activation of GPRS ...
they will tell you the procedure to activate it ....
they will tell the number to which the message to be sent to recieve the settings ....
so note that down and then follow the procedures told by them ...
you will receive the gprs settings(profile) also ... make sure of the charges with them there will be many plans & then get activated ...
after this you will able to connect to internet ....
if the customer people tell you that your handset is not compatible then you must tell to give the manual settings(includes ip address,APN,etc) so that you can only create the profile and input the information given by the customer care people...
any further doubts reply me
i am always here to assist you ..
thank you
bye...
Nokia 3230... | Answered on Apr 05, 2014
i want the unlock code for my smartmovie 4.15 of my nokia n81 device serial no. is 356994014532604
pls.... send fast
Nokia 3230... | Answered on Mar 22, 2014
unlock key number of 3230 nokia
Nokia 3230... | Answered on Feb 15, 2014
once format ur nokia 3230 and use again useing this code *#7780#,
Nokia 3230... | Answered on Jan 18, 2014
first of all tel me your phones imei no. then i will tel you the license key
Nokia 3230... | Answered on Nov 13, 2013
I forgot my MicroSd password.Please help me to remove it.I am unable to access my MicroSD card.I have Nokia 6300
Nokia 3230... | Answered on Oct 26, 2013
if u really went to any nokia support center who's specified for fixin' the nokia phones they'll tell u that the logic circuit is down i had tha same problem and the phone center (RA'A) in egypt have fixed my phone for only 300 EP = 52.99 Dollars so go and check it out
Nokia 3230... | Answered on Oct 17, 2013
3230
Nokia 3230... | Answered on Sep 03, 2013
hi my name swapnil navgire plz send me my imei number 354553013813696 unlock key
Nokia 3230... | Answered on May 29, 2013
Nokia 3230 Cellular Phone Logo
608 questions posted
Popular Products
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
mobile lcg juke box player unlock key
  • Cell Phones
