20 Most Recent
Nokia 3120 Cellular Phone Questions & Answers
How do I cancel predictive spelling (preferably permenently)
Go into an app that has the keyboard. Your Texting app is good.
In the bottom left corner of the keyboard there should be a key with a gear on it. Hold your finger on that key until the screen turns into a keyboard Settings menu.
Go to Input/Input and uncheck the autocomplete button.
Nokia 3125 dead set plz
If
your mobile is dead then please check is it charging or not if it is
charging then it means your mobile is not dead it is just software
problem for that you should reinstall the software it will start
working. & if it is not charging then there is a problem with your
mobile mother bard for that you should visit your nearest Nokia service
center they check what happen to your mobile & they will solve it.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
I have forget my reset password my imei number is 354849026322620
Press the "Menu" key on the Nokia 3120 Classic's home screen. 2. Select "Settings" and select "Security Settings" from the list of available options, try this if not you will have to ring provider for reset code all phones makes and models have a different code
Pls help me fix the timing difference
this depends upon the service provider time zone and the model of phone used by the sender...
usually some of the service providers use GMT but mostly all use their standard time zones...
so this might hapen most of the times..
thanks
