20 Most Recent
Nokia 6020 Cellular Phone Questions & Answers
How can i get my password?
Are you looking for the security code to unlock the cell phone so you can use the phone with a different phone service provider/SIM card?
First Try it:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
OR:
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Handphone nokia 6020 I have
Please enter 4235363721 when the phone asks for the security code.
Hope it helps. Please rate the answer. Thanks for using FixYa.
How to unlock security code for nokia 6020
If you had lost your security code you can reset it by the following steps. Press the green button without releasing it press the star button then press 3 then the power off/on button. Your device will restart then change it in the settings security tab. The default security code is 12345
Nokia 105 code
Hi are you looking for network unlock code to unlock your Nokia 105 mobile from network provider .Then visit sites like
ProUnlocking.com they are rendering network unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone ...
Insert memory card
You can' t insert a memory card in this mobile because it doesn't have a card slot!
Nokia 6020 speaker problem
you have to be more specific about this issue...if you are having problems with your speaker on the phone then have it replaced by taking it to a mobile service center or a professional mobile tech
Enter restriction code
You can get the restriction code for your Nokia 6020 phone
from
Unlock-Zone.com here you need to specify your country, Network name to
which it is locked, IMEI number of your phone. Then they deliver restriction
code to you through mail with unlocking instructions. By using this you can
unlock your phone from Network lock easily.
