20 Most Recent
Samsung SGH-t219 Cellular Phone Questions & Answers
Error message "Number FDN restricted"
I can receive the call from outsider but wont be able to make call to outsider. When I trying to dial out to somebody it says "number FDN restricted" Please help.
Cannot make outgoing calls
What does it mean when registering it n says "your sim card does not allow a connection to this network" n how do I get it to work?
Sim card not working sim works in other phone
The first thing you can do if you think there is aproblem with the phone settings is that :
Go into network setings of the phone and choose MANUAL in the Network selection. Then you can search for the Lebara network manually and select it, if it works.
Or if it doesnt work, then the phone probably might have been locked. Just check it once, using any other network simcards it your phone. If it is locked, you can easily get it unlocked in your local market.
Pin blocked
You entered your pincode wrong 3 times or more. You need your PUK code to undo. Your provider can provide you with this. There is NO otherway to unblock this (so called 'unlocking' is something else).
Best regards,
Nokia x2 sim unlock
Use unlock code to remove the Sim lock from your Nokia X2. Get the code from the site
Mobile-Unlocker.com ,and unlock it using unlocking instructions which is given in the site itself.
How to unlock bb 9530
To unlock Blackberry 9530 model phone from network lock use unlock code.Visit the site
Theunlockspot.com get Unlock code at reasonable cost and unlock it.You need to specify the network and country it is locked now to get the unlock code.
Samsung SGH-T139 cellular phone 3D010017
All you have to do is: 1)take battery out. 2) put battery back in. 3) before the error message has time to come on type #06# or *#06# on keyboard.Wala.I did this and it worked!!!!!!!!!!!!!
We have a samsung sgh-t219. The phone states that
If you are trying to use a SIM card in your phone and
getting a message like "Enter Subsidy Code", "Incorrect SIM
Card", "SIM not provisioned" , "Emergency Calls Only" or similar messages, then you need
an unlock code for your mobile phone. You can get Samsung SGH-T219 Unlock Code from the
network provider, they will provide a code with easy to follow instructions on how to unlock your phone. You may check Samsung Unlock Code
site, they can open up all networks for you where you want to use your phone. Once your phone is unlock, it will work with any networks worldwide without sticking to one network only.
Hope this is helpful.
Thanks.
