20 Most Recent
Nokia 9300i Cellular Phone Questions & Answers
Free Unlock Codes
This is DCT Nokia phone.So you can get free unlock code for Nokia 9300I model phone from
Unlock-free.com and unlock it.You can get Unlock code for Latest Nokia Phones from the site
Unlocking4u.com and unlock it from network lock easily.
How to format my nokia 9300i
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
I need nokia 9300i's format
Inorder to format your set,you can use following tips; FOR HIGHER ORDER PHONES(LIKE N,X,E series..): Dial *#7370#
then your phone will ask a securitycode,there you can type your code.then it wil format and restart.
FOR OTHER MULTIMEDIA NOKIA PHONES: Here you can't format yourphone,but you can reset it; For that,go to;SETTINGS-RESTORE FACTORY SETTINGS- AFTER CLICKING IT, your phone will ask a securitycode there you can type your code.then it wil format and restart. "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
Reeset security
if you want security reset you need to get you master key, post me if you have that or otherwise i will send you a link where you can get master key for your phone
9300i
settings, restore orginal settings!!
tnx
Im having a network problem with my nokia 9300i
Restart the phone. If that doesnt help, contact your carrier and explain the problem to them. Many cell phone problems cannot be fixed by the user but by the company. Just call them up, and explain the problem.
Do 9300i suport themes
Hello
Ok, if i understand you correctly you want to download new themes for your phone?
At the link below you will be able to find new themes and download it free of charge. just look around in the page and you will find what you are looking for .
http://www.mobile88.com
Hope this can help.
rate this please
How can i find a software to browse free of charge
Opera mini is the greatest . But here is another browser called skyfire : www.skyfire.com or teashark . But i still recommend Opera mini .
your rating is very important for me , that's why I've helped you .
good luck .
Nokia 9300i displays NOKIA on the inside but blank screen after t
I have the same problem! I stripped mine down - quite easy with a small star driver, but take care - and cleaned the ribbon cable connectors with alcohol. I cleaned everything else that I could for good measure. It worked for quite a while, then just stopped again. I noted the backup battery is dead - I wonder if this has anything to do with it?
How do i transfer data on my nokia 9300i
go to nokia web site. choose your mobile model and download its software.
normally nokia uses pc suite software.
better download it from Nokia you will get it with its driver.
once you installed the pc suite, open it, you will see an icon " file manager" to transfer data from mobile to pc or pc to mobile
hope that helped you
