20 Most Recent
DISH Network IR Remote Control Questions & Answers
COMO PROGRAMO LA TV A MI CONTROL REMOTO DE DISH
Hola! mi nombre es Kimberly Escobar trabajo con DISH Network. Para programar el control remoto con su television hay ciertos codigos que se pueden integrar al control para que pueda funcionar con la television estos codigo son diferentes dependiendo de la marca de televisor que tenga. Es importante saver cual es la marca para saber que codigo se va a integrar este link puede ser de mucha ayuda aqui puede encontrar los codigos necesarios y el procedimiento a como integrarlos
http://www.dishnetwork.com/SupportSection/remote-setup si tiene preguntas adicionales o necesita mas ayuda por favor contactenos directamente al 1800-333-DISH.
The tv is jammed. Remote
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux modes. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with!
-Kirstie DISH Network
HOW CAN i RESET SAT
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
http://www.dishnetwork.com/SupportSection/remote-setupRemotes and receivers models:
222 -
21.0 IR / UHF Pro
222k
- 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k
- 21.0 IR / UHF Pro
Ray Calo
DISH Network
Perdi la hoja de codigos
perdi mi hoja del mi control remoto y no lo puedo programar la marca de mi tv es sonic si m podrias ayudar gracia
Como puedo programar una tv
Hola! Mi nombre es Kimberly Escobar con DISH Network, sera un placer proveerle la informacion que necesita. Para programar el control remoto a su televisor Samsung hay ciertos codigos que puede integrar al control para que funcionen con la t.v. Los codigos para un televisor Samsung son los siguientes: 738, 516, y el 680. El procedimiento a programarlo el el siguiente: Oprima el boton de t.v localizado en la parte de arriba del control por 5 segundos hasta que todos los demas botones se iluminen rojos, una vez esten iluminados ingrese uno de los codigos seguidos por el signo de numero (#) por ejemplo 738# el boton de t.v deberia iluminarce 3 veces, despues de esto puede tratar las funciones. Si tiene preguntas adicionales puede contactarme directamente a
[email protected]Kimberly Escobar
DISH Network
[email protected]
Nesesito los codigos para controlar mi tv
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer asisterle proveendole la informacion que necesita. Algunos codigos que pueden ser programados a un televisor Panasonic so los siguientes: 700, 734, 512, 644, and 685. El procedimiento a integrar uno de estos codigos al control para que funcione con la T.V es el siguiente: oprima el boton de T.V localisado en la parte de arriba del control hasta que los demas botones se prendan en rojo, una vez esto suceda ingrese uno de los codigos seguido por el signo de numero por ejemplo 700#, el boton de T.V deberia iluminarse 3 veces en rojo despues de esto puede tratar el control para verificar que funcione. Este link tambien le puede ser de mucha ayuda aqui encontrara mas codigos e informacion a programar el control
http://www.dishnetwork.com/SupportSection/remote-setup. Si necesita informacion adicional o mas ayuda por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le ayude.
Hola mi nombre es jose
Hola mi nombre es Kimberly Escobar con DISH Network lamento mucho que este experimentando este problema. Sera un placer ayudarle y proveerle la informacion que necesita. Para programar el control de DISH Network con su televisor va a necesitar integrar un codigo que sea compatible para el control y la t.v. Ciertos codigos que se pueden integrar al televisor son los siguientes: 678, 156, 520, 505, 654, y 627. El prcedimiento para integralo es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 654#. El botond de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si necesita ayuda adicional puede visitar este link aqui puede encontrar mas codigos y el proceso a programar el control
http://www.dishnetwork.com/SupportSection/remote-setup Tambien puede contactarme directamente a mi correo electronico
[email protected].
DISH Network
Kimberly Escobar
[email protected]
Have an Element Tv need
Hello there this is Kimberly Escobar with DISH Network, just ran across your post and would like to help by providing you the information you need. To program the remote control to your television we have certain codes that integrate into the remote allowing it to function your T.V. Some of the codes we have for Element brand T.V are 627, 659, and 902 the procedure to integrate them is the following: Press and hold the clear T.V button located at the top of your remote until all the other buttons light up in red, once you see all the buttons lid enter one of the codes above followed by the pound key, for example 627# the T.V button should light up 3 times. After this u can try your remote to verify it works. You can find more information by following our website www.dishnetwork.com here u can find more codes for any brand of T.V and the procedures you need. IF you have any questions or concern please contact us directly we will be happy to assist.
