20 Most Recent One For All URC4220 Remote Control Questions & Answers
4answers
Need to set my one
Try the following codes: Toshiba 0060, 0154, 0156, 1265 . Turn on the TV manually and then press the TV button on the remote. Press and hold Set until the LED blinks twice; then release the button. Enter the four digit code. The LED should blink twice again. Test if the TV turns off by pressing Power once. If it does, check if the other features of the remote control the TV. If it doesn't, try a different code. You can also manually search for a code by pressing 9-9-1 after holding and releasing Set. Then alternate between pressing Power and TV (for a TV code). Lock in the code when the TV turns off by pressing Set. Check if the remote works for other features.
You can get the manual and codes for the One For All remotes here: http://www.oneforall.com/support/manual .
If your remote is older than your TV, you may need a new remote. Universal remotes are usually limited to codes for devices released 6 months or more before the remote was programmed.
I hope this helps.
3/13/2022 12:48:58 PM • One For All... • Answered on Mar 13, 2022
Does URC-3920 Remote Control work soniq tv
Try to find it out in manual One For All URC 3920 URC 3940 Or use automatic code searching mode
3/22/2017 11:30:52 AM • One For All... • Answered on Mar 22, 2017
2answers
Need codes for All For One URC 4220
check out www.oneforall.com and click on USA then click on product support, pick your remote and click it then scroll to toward the bottom and click on get codes and they will all pop up.
9/29/2016 9:57:39 PM • One For All... • Answered on Sep 29, 2016
2answers
How do i program my one for all remote mode
I can help you reprogram your URC-3220 Universal Remote for your Magnavox TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide.
I hope that helps.
8/20/2016 10:28:33 AM • One For All... • Answered on Aug 20, 2016
2answers
Looking for remote codes for urc-3220 to my
I can help you reprogram your URC-3220 Universal Remote for your Signature TV.
I hope that helps.
8/20/2016 10:22:34 AM • One For All... • Answered on Aug 20, 2016
Urc 4220 code list
Check these links for details. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
8/20/2016 12:53:29 AM • One For All... • Answered on Aug 20, 2016
Need code for panasonic tv
Go to link below to download the full operating manual for your one for all urc4220.One for all URC4220 manualYour welcome.
8/20/2016 12:22:09 AM • One For All... • Answered on Aug 20, 2016
7answers
One for all URC4220
go to one for all universal remotes
8/20/2016 12:20:20 AM • One For All... • Answered on Aug 20, 2016
Need code for UCR-3220 to run TV SV2000
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your TV.
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
8/17/2016 10:02:45 PM • One For All... • Answered on Aug 17, 2016
2answers
Need code
I called one-for-all and got a repair number and then sent the remote to them to have the codes added.
7/21/2016 6:20:51 AM • One For All... • Answered on Jul 21, 2016
Need codes
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
1/20/2016 10:44:49 AM • One For All... • Answered on Jan 20, 2016
Where can I find codes
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://electro-medical.blogspot.com/
11/17/2015 5:43:00 PM • One For All... • Answered on Nov 17, 2015
I need codes
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. http://electro-medical.blogspot.com/
11/17/2015 5:42:36 PM • One For All... • Answered on Nov 17, 2015
I need the code to make a rca converter box work with remote
0281.0222. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/ Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy
4/9/2015 3:23:30 AM • One For All... • Answered on Apr 09, 2015
2answers
Codes for remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
4/1/2015 1:42:38 PM • One For All... • Answered on Apr 01, 2015
Set up guide for URC-4220
2/19/2015 10:25:04 AM • One For All... • Answered on Feb 19, 2015
How do I program a one for all remote and how do I get the codes in English?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
2/11/2015 8:43:24 AM • One For All... • Answered on Feb 11, 2015
What is the code for a sanyo tv and how do I program it
If your TV is older than the URC-4220, the code should be 0154. (The universal remote generally can only control devices that were released about 6 months or more before the remote was programmed.) To program the remote, turn on the TV manually. Then press the TV button on the remote once. Press and hold Set until the LED blinks twice. Release the Set button at that point. Enter 0154, check if the LED blinks twice again. If the LED blinked properly, point the remote at the TV and press Power. If the TV turns off, this is the correct code. If you take too long between steps, the remote may leave the setting mode. If the LED didn't blink, start over from pressing the TV button on the remote. The manual for the One-for-All URC-4220 remote is available here: http://voxrightnow.custhelp.com/app/answers/detail/a_id/11828/~/programming-and-operating-the-oneforall-urc4220-universal-remote-control . Scroll past the directions for using and programming the remote to the link to the Owner's Manual. The list of codes starts at page 36. I hope this helps. CIndy Wells
2/11/2015 12:26:29 AM • One For All... • Answered on Feb 11, 2015
Ineed code for craig dvd player
helllllo.......okaydoky.......anonymous.......go to goggle put in your remote model an your dvd player an they have the codes...........tk.........g.scott
10/6/2014 3:48:28 AM • One For All... • Answered on Oct 06, 2014
676 questions posted
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • One For All Televison & Video
Most Popular Question
ineed code craig dvd player
  • Televison & Video
