20 Most Recent
RCA RP4803 Clock Radio Questions & Answers
4803
HelloI've the user manual for your RCA RP 4803 clock radio. But I can't send it to you by this site, as this window does not allow me to upload PDF files by it. If you want to get it, you have to buy one amoung my services published by FiXya. According to FixYa new site, I can't upload any PDF files to customer, without Fixya's permission. Just buy one amoung muy services. You can access my services by typing my nickname "gopakumarg43" in Google search box and click search. Clik on 'gopakumarg43-FixYa" and you can see all my services there, published by Fixya. You can access directly to it, which in turn let you ot get into Fixya site. There is on service provided by me to send manuals for clocks and clock radios. You can select ti and can access me. OK.
C.D. keeps skipping.
If you look below there is a concise post for the same problem already. CD problems are universal as are the workarounds. Defective tracks, damaged discs or dirty/defective player. Economics, as he says, prohibits actually repairing most low-end products.The web is full of information and advice. This one leaves no stone unturned.
http://www.repairfaq.org/sam/cdfaq.htm
Set alarm clock
goto
http://voxrightnow.custhelp.com/app/answers/detail/a_id/12057/~/operating-the-rca-rp4803-clock-radio
or follow instruction
- Press the SET button until WAKE 1 / WAKE 2 icon is blinking.
- Press REV or FWD to set the wake time. The time decrements or increments will follow by a faster rate when you press and hold either REV or FWD.
- After the WAKE time is set, press SET repeatedly until no icon is blinking.
Tips:
- The unit equips with GRADU- WAKE feature, the alarm tone volume will increase gradually to its maximum in about 30 to 45 seconds.
- If you set the SLEEP function with low volume level before going to bed, we advise using WAKE mode to wake you up since its volume will automatically increase.
Waking by Selected Source: You may be woken up by WAKE, RADIO or CD.
- Select an AM or FM station.
- Set wake time (see above directions).
- Press WAKE 1 or WAKE 2 to select waking up by WAKE, RADIO or CD. Corresponding indicator will be shown next to the selected setting.
- Adjust the volume by turning VOL.
You can select your CD wake track by the following procedures:
- Make sure you have inserted a CD.
- While holding WAKE UP CD TRACK, press REV or FWD to select your desired CD wake up track.
How do you set time
Use the manual in the following link. It's for a similar model, so perhaps they work the same.
http://portablemedia.manualsonline.com/manuals/mfg/rca/rp5430.html
My RCA home theater system,
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
1/15/2024 9:01:27 AM •
RCA Audio...
Answered
on Jan 15, 2024
Can I burn a CD from a tape on an RCA Model # 8530?
The RCA Model # 8530 appears to be a stereo receiver, which means it does not have the capability to directly burn a CD from a tape.
To convert a tape to a CD format, you would typically need a separate device called a cassette deck with a built-in CD recorder or a computer with the appropriate hardware and software.
If you have access to a cassette deck with a CD recorder, you can connect the RCA Model # 8530's tape output to the input of the cassette deck and then use the cassette deck's CD recording function to transfer the audio from the tape to a blank CD.
If you have a computer, you can use an analog-to-digital converter to connect the RCA Model # 8530's tape output to the computer's audio input. You can then use audio recording software on the computer to capture the audio from the tape and save it as a digital file. Once you have the digital file, you can use CD burning software to create a CD from the captured audio.
It's important to note that the specific steps and equipment required may vary depending on the exact models and setup you have. It's recommended to consult the user manuals for your devices and, if needed, seek additional guidance from the manufacturer or a knowledgeable audio technician.
6/18/2023 4:27:03 PM •
RCA Audio...
Answered
on Jun 18, 2023
