20 Most Recent Westinghouse 16093 Remote Control Questions & Answers
Yes,it shorted the remote.Replaced it with the new one,but make sure also check ur wiring in the fan to see it clean and dries or could short out the whole house,and cause fire.
Westinghouse... | Answered on Jul 18, 2015
WESTINGHOUSE 0143 0114
WHITE WESTINGHOUSE 0100 0130 0138 0136 0227 0279 0080
Westinghouse... | Answered on Apr 08, 2014
follow this instruction and fix it. God bless you
No picture
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
Westinghouse... | Answered on Aug 01, 2013
Try these codes listed for Sony.  10080 11100 10111
 One of these should work.
Westinghouse... | Answered on Oct 20, 2012
Need the firmware update and the codes still do not work... About ~ 40 scans in and my vr-4085 worked. Tried all codes prior. No luck.
This works on rc-65
There is no other setup code indicated for your product
that links to the model number you entered.
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    • 1 for Televisions
    • 2 for "AUX 1" devices - VCRs or DVDs
    • 3 for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Westinghouse... | Answered on Jun 28, 2012
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Westinghouse... | Answered on Apr 21, 2011
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Westinghouse... | Answered on Apr 19, 2011
Hello mwhinz, there are currently no codes set up for your TV, what you will need to do is call 1-800-701-0680 or send me a quick email to westytech@westinghousedigital.com to get the FW via email that will allow you to program your remote using different codes other than Westinghouse codes. Please make sure you include the model #, serial #, and TW # all located on the back of the TV. Please rate my answer if it was helpful.
Westinghouse... | Answered on Feb 17, 2011
Westinghouse 16093 Remote Control Logo
57 questions posted
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
direct tv remote need code westinghouse
  • Televison & Video
