20 Most Recent
Vtech 5.8GHz Analog Cordless Phone Questions & Answers
How to change from pulse dialing to tone on vtech 5.8GHz
Here are the instructions for one vtech phone (may not be quite the same as yours but may work or give enough hints for you to figure it out):
Press PROG.•
Press ? or ? until the screen displays DIAL MODE: and the current setting.
Press SELECT. The current setting blinks.
Press ? or ? to select TONE or PULSE.
Press SELECT to save.
How do I register a cs6114 phone
Do you need to register a handset? Make sure the battery is fully charged on the handset and remove the handset from the base. With the phone not in use, press and hold the Find Handset button on the base. After about 4 seconds, the In Use light should light up. Now press the # key on the handset that you need to register. It should say Registering and then complete the registration within 60 seconds. This will only work if the base has power and is connected to a working phone line.
If you need to register the phone with Vtech, go to
http://www.vtechphones.com/support/general/product-registration .
I hope this helps.
Don't have pin number to check my voicemail on cs6419
The CS6419 isn't an answering machine. To gain access to your voicemail, please consult the documentation for whatever answering machine or voicemail system you have on your telephone line.
If you require further assistance, please add a comment to this question identifying the answering machine or voicemail system.
