20 Most Recent
AT&T E5813B Trio Cordless Phone Questions & Answers
AT&T E5813B
You have to hang up the first phone then press the "phone on" button twice on the second phone.
How to register AT&T Synj SB67108 to new base unit SB67138?
Register SynJ SB67108 Handset
To register an AT&T SynJ SB67108 handset to a new SB67138 base unit, you will need to follow these steps:
- Make sure the new base unit is plugged in and turned on.
- Press and hold the "Menu" button on the handset until the display shows "Menu."
- Use the navigation buttons to select "Registration" and press "Select."
- Select "Base" and press "Select."
- The handset will begin searching for the new base unit.
- Once the base unit is found, it will be displayed on the handset's screen.
- Select the new base unit and press "Select" to complete the registration process.
- The handset should now be registered with the new base unit.
Note: if you have multiple handset you need to register, repeat step 2-7 with each handset.
