20 Most Recent Eureka 5893AVZ Bagless Upright Cyclonic Vacuum Questions & Answers
2answers
The handle for my Eureka 5893 AVZ was getting very
usually if a connection gets hot enough to start melting it is usually a loose connection or high current. more than likely the switch is bad if you replace it with the same type of switch and it gets hot check the motor. make sure it is clean and isn't jammed
6/9/2019 11:11:35 AM • Eureka 5893AVZ... • Answered on Jun 09, 2019
2answers
It is plugged in but vacuum does not start. I
if the belt is loose the motor wont run just a guess
6/9/2019 11:08:55 AM • Eureka 5893AVZ... • Answered on Jun 09, 2019
Eureka 5893 roller does not spin
check the belt on the brushbar is not broke click the link below for the manual ,that will give you full instructions how to replace it ,,,,,,,,,http://www.eureka.com/FileLibrary/d9d3256193114e4a96be2cf719fd5bed/74227.pdf
1/20/2013 6:24:19 PM • Eureka 5893AVZ... • Answered on Jan 20, 2013
My eureka enviro vac shut
Same thing happened to me. I checked the owner's manual and it turns out the Eureka Envirovac has a built-in thermal cut-off switch. So anytime the motor gets too hot, it just shuts down. Most of the time this is because it gets plugged or the filter is too dirty. In my case, the dust basket thingy and filter were clogged beyond belief. Probably would help to clean that more regularly in hindsight. Supposedly it will turn back on after the recommended 30 minute wait.
11/3/2012 1:22:04 PM • Eureka 5893AVZ... • Answered on Nov 03, 2012
Brush roll turning very slow
You might need to clean out the roller brush. Here is the manual that has instructions:
Owner's Guide (1.5 MB download)
If you need a new belt you can get it here:
Eureka style D belt
10/15/2011 3:15:17 PM • Eureka 5893AVZ... • Answered on Oct 15, 2011
0answers
0answers
My brush roller is loose
I Have the same problem. It is the end of the brush roller opposite the belt end. It binds up and gets hot, then melts the plastic piece on the end of the brush roller. Have to order a new brush roll which is about $20-$25+shipping
12/3/2010 2:15:45 AM • Eureka 5893AVZ... • Answered on Dec 03, 2010
3answers
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
11/23/2010 11:14:58 PM • Eureka 5893AVZ... • Answered on Nov 23, 2010
Every 3 swipes on the floor I have to push the
No, it is not normal for the brushroll to stop that often. You may need to clear any thread, etc from the brushroll underneath the vacuum. Remove the screws from bottom of unit, stand unit upright, turn height adjustment dial to either side to allow hood to come off. Check the belt for any stress marks, stretching, etc. Replace the belt if necessary.
9/5/2010 9:00:44 PM • Eureka 5893AVZ... • Answered on Sep 05, 2010
Not picking up all the dirt and hair. The brushes
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
8/8/2010 8:36:48 PM • Eureka 5893AVZ... • Answered on Aug 08, 2010
Vacuum shut off while in use. almost new. now it
Not sure if this will help, but this is how my problems began, then I noticed the handle getting very warm. This went on for a few weeks (used the vacuum maybe 4 times).
Eventually, the handle got hotter and hotter, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
1/30/2010 10:39:55 PM • Eureka 5893AVZ... • Answered on Jan 30, 2010
2answers
The handle was getting hot and we opened the
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
1/30/2010 10:35:24 PM • Eureka 5893AVZ... • Answered on Jan 30, 2010
2answers
The handle for my Eureka 5993 AVZ was getting very
try cleaning all...
if have sam paoblem need replaced main motor....
1/30/2010 10:06:03 PM • Eureka 5893AVZ... • Answered on Jan 30, 2010
New Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
11/16/2009 1:34:59 PM • Eureka 5893AVZ... • Answered on Nov 16, 2009
Eurika Vaccuum 12V Mega Boss - the suction is fine
There is a blockage behind the brush between where the suction tube hooks up and the brush.
10/20/2009 1:52:25 AM • Eureka 5893AVZ... • Answered on Oct 20, 2009
Eureka 5893AVZ Bagless Upright Cyclonic Vacuum Logo
33 questions posted
Top Eureka Vacuums Experts
Mike Cairns
Mike Cairns
Jo Ri
Level 1 Expert
Alexander
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Eureka Vacuums
  • Eureka Vacuums
Most Popular Question
  • Vacuums
