20 Most Recent Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier Questions & Answers
You can replace the fuse by soldering a new one into place -- it's a standard fuse, just match the amp rating of old to new.
Chances are though, after you do this, it will blow again. So, there's a good chance the unit is kaput.
I have extensive experience with these units to the point of even replacing the high-voltage field wires (the two fine wires which run from top to bottom) with titanium wire. There is no real good way to keep these things running properly -- they're kinda like weed whackers -- inherently problematic.
Sharper Image... | Answered on Jul 06, 2018
Oh there are a lot of known issues! I used to work for sharper image and I believed in this items very much so until mine broke. However after a year I figured out how to fix it. Take the big square collection grid out and the back screen off. Now get you a thick rag and be very careful because there are several tiny wires going up and down. Smaller than dental floss, you need to be very careful because you can either brake them or slice your finger wide open( Under any circumstances I can not be held liable for the information I am giving you try this at your own risk). Now with the towel very gently go up and down each wire like you are polishing a brass pole(once again these wires are thin and can break or cut you). Do this from the back side of the unit and from the inside where the collection grid that you took out sits. Take your time and be thorough, and presto your 400 dollar air cleaner is working again.
Sharper Image... | Answered on Jan 25, 2018
This does NOT work. The electric guitar wires burn out in 1-2 months.
Sharper Image... | Answered on Apr 28, 2017
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commission is going to be making a decision on ionizers at the end of year since there are hazards in the air from using the devices. It could be that ionizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it.
Sharper Image... | Answered on Dec 31, 2016
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Sharper Image... | Answered on Jan 01, 2016
Hi.
This appliance simply resets by disconnecting the power cord for five minutes. The control board does not include battery.
If the model was manufactured before 2007, pleas read below.
Ionic Breeze Concerns
Regards.
Ginko.
Sharper Image... | Answered on Apr 01, 2015
Bad limit switch for the removable fin bar Connected the red wires together
Sharper Image... | Answered on Feb 02, 2014
They need a very thorough cleaning.
You can use a soapy solution 1st, then wipe them dry.
Then follow with a 50/50 solution of water & vinegar. Clean well on all the metal cells, then rinse wipe with damp cloth then wipe as dry as you can.
Allow to dry overnight, ensure that the cell is very dry prior to starting.
Then final thing - keep inverting upside down then right side up numerous times. You want the little beads to slide up & down the wire. This will clean that as well.
Sharper Image... | Answered on Jan 29, 2014
Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier Logo
151 questions posted
Top Sharper Image Air Purifiers Experts
Ekse
Marvin
Marvin
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Sharper Image Air Purifiers
Most Popular Question
2 model si861 ionic breeze units
  • Air Purifiers
