20 Most Recent
Uniden D1780 Dect 6.0 Cordless Phone With Answering System Questions & Answers
D1780 with blank screen
Suggest you reset handset and register again with base.
Instructions from manual...
Resetting Handsets If you have trouble with a handset or if you want to replace one, clear the registration information from the base and the handset: 1. Press & hold END and # at the same time until you see the System Reset menu. 2.If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable. 3. To confirm, select Yes. The handset displays Handset not registered. Registering Handsets If you see a "not registered" message on a handset, you must register it to a base before using it. 1. Place the handset in the base; the display should say Handset Registering. 2.Wait until the display says Registration Complete (about 30 seconds), then pick up the handset and press TALK/FLASH. 3.If you don't hear a dial tone or the display says Registration Failed, charge the battery completely, then try again.
How do you take the silent mode off
Press and hold the # button (below 9) to toggle the Silent Mode on or off. When you turn it on, it will prompt you for how long you want the silent mode to last. If you do nothing, the silent mode will be enabled for Always On 5 seconds after you press and hold the # key.
If you turn off the answering system, the silent mode will be disabled.
I hope this helps.
Voice indicator light blinking-D1780
Do you mean the voicemail indicator? This indicates that you have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Cordless phone system does not record caller IDs
I can only tell you that I had similar problems with my Uniden system. My solution, after much frustration, was to buy a $25 AT&T answering machine and add it to the system. I then turned off the Uniden recording capability and for the last two years have been very happy. I use Firefox which has an extension (found as an add-on) called PriceBlink. Once I brought up the web page describing the answering machine, PriceBlink notified me that the best price was, not amazingly, was in Amazon dot com. PriceBlink also shows the price for S&H. If you use Chrome there is a similar extension whose name I have forgotten, but it is equally effective. I won't use IEx, so if you're looking for a best price and not using Firefox or Chrome I can't tell you how to find a best price, but just google "Telephone Answering Machine" (with the quotation marks) and see what's there. There aren't a lot of them - they're a dying breed. I've given up on Uniden. One of the satellite phones stopped working after about 18 months. I don't buy extended warranties, so that one was trashed.
