I followed a comment from a previous source and reversed the polarity of the batteries. I then flipped them back to the correct position and the flashing battery indicator went away and the thermostat functions correctly.
Hello, the snowflake flashing is a (supposed to be) 5 minute delay to prevent short cycling of the compressor. This delay can sometimes get stuck thus requiring replacement. To test , remove top of thermostat to where you can identify wires and terminals. Have someone stand near the ac unit for this test, and then take a wire or paperclip and briefly touch Rc to Y. This should start the outdoor unit. R to G will start the indoor fan
your thermostat may be locked go to honeywell web site punch in thermostat model # and look for set up pushing two button at the same time gets you in but you will need instuctions for set up If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
It could be the breaker is tripped or the blower is not getting power. Check your transformer to make sure you are getting 24 volts going to the fan relay sequencer and make sure you check your capacitor that is connected to the fan as well. sounds like a minor electrical hiccup. Also check your thermostat wires and pay close attention to anything marked w1 or w2 as these are the terminals that control the heating part of your system.
You have to take the cover off and get inside and unhook a wire. You may have 3 wires unhook 1 and if that doesn't turn it off hook it back up and unhook the next. One of them will turn it off!! Then go to the hardware and get another thermos!! You won't get a shock or anything cause it's not hooked up to any power source, they are just sensor wires. I don't know much about Honeywell, I just know I don't like their thermos. Had one once and had nothing but trouble w/it !!
That's very unlikely. I'd sooner believe the cat has been playing with it or it gets changed when someone wearing a backpack brushes past it (sometimes the straps or zipper pulls snag the oddest things). You can get a thermostat guard to prevent this if your landlord permits it.
Question edited for clarity.
Installation manual, but it has some very specific requirements. You may not have the correct one.
The RTH6360 thermostat does not support L/A, S, or U terminals. If there are wires in terminals that are not listed, you will need additional wiring support. Visit yourhome.honeywell.com/support to find out if the thermostat will work for you.
I don't understand that, and if you don't, you need a heating or electrical engineer.
Here at home where I reside we have an old school thermostat that has the mercury bulb that acts like a sensor, and in other cases it could just be as easy as replacing the batteries in the unit itself, usually a lid that hides them, sometimes it works
Here are some options:
Honeywell Home Non-Programmable Thermostats: These thermostats are designed for simplicity and comfort control. They come in a range of models, from the classic circular dial to easy-to-use soft-touch buttons and backlit displays. You can easily set your preferred temperature with the touch of your hand. The Honeywell Home website has a range of non-programmable thermostats to choose from .
Honeywell Home Programmable Thermostats: These thermostats allow you to set different temperatures for different times of the day. This can help you save energy and money on your heating and cooling bills. The Honeywell Home website has a range of programmable thermostats to choose from.
Honeywell Home Digital Non-Programmable Thermostat RTH5160D1003/E: This thermostat is simple and intuitive to use. It has a backlit screen and basic button functions that make it easy to control the temperature. Once you set your desired temperature, the thermostat stores it in its memory, even during a power outage. Non-Programmable Thermostats ' Honeywell HomeRTH5160D1003/E Non-Programmable Thermostat ' Honeywell Home Might as well look at the programmable ones on their site. Check their customer service if you have an additional question. The above mentioned should work with your setup.
They all hide in the thermostat base.
Load on the contacts is 24 vac standard, 30 volts max. the battery however is a standard AA or AAA Duracell battery, it is not 30 volts.... Those are available almost everywhere, You can pry the front of the thermostat from its wall mount sub base and see the batteries inside... just replace them.
Apr 18, 2017
