20 Most Recent Hunter Fan Company 5/1/1 Programmable Thermostat Questions & Answers
Hummm... how far is your Thermostat from your heater? I am reading your extensive manual but there is no mention of that distance? There was a early mention of batteries? Are yours fresh?
Is this a 'new' problem? Has it worked properly before?
Then there is this from the manual:
The installer can set SYSTEM functions once the thermostat is installed. The
default settings are shown in bold in the following list. Options are listed inside the
parentheses. Example: the default SYSTEM TYPE is CONVENTIONAL with (HEAT PUMP) as a second option. See pages 28-29 to change these settings.
Have you tried resetting your Thermostat?? Sometimes these basic 'onboard' computers get confused... especially true with lots of 'options'...
It's a little hassle to get a DIGITAL copy of your manual (I am not a Robot ~ etc) ~ but here it is:
Download manual
TROUBLESHOOTING begins at Page 68
Anthony
Hunter Fan... | Answered on Dec 24, 2017
This should help you. You need to know if your thermostat is powered by the unit or independently and which way your reversing valve switches (I,m not sure on a Bryant, but probably Your old O wire goes to your new O terminal. They should pretty much match up, the new stat just has more options. Thermostat wiring
Hunter Fan... | Answered on Jun 09, 2017
hi,
Ive been looking for about 20 minutes now and unable to find a direct link to the owners guide, I did locate the phone number for wickes support for you..
Please contact our Customer Services on 0870 608 9001 and we will be able to assist you.
jm
Hunter Fan... | Answered on Apr 08, 2016
try: (888) 880-FANS their office will probably send it to you.
Hunter Fan... | Answered on Feb 05, 2016
If you don't have the wiring information, go here: http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/42710.pdf and see page 10.
If you're still having problems, go down to the furnace room and find the piece of equipment that you're wiring to.  See where the wires came from, transpose that to the information above.  Note: the wiring from the relay box should be 24 volts which is safe to handle.  Wiring inside the relay box may be 110 or more volts which is not!!!  Cut power before opening relay boxes.
As far as heater running continuously, be sure of your wiring.  You may have the gas relay lead and the fan lead reversed.  Determine if you've set the switch options for your type of heater correctly!!!  Do you hear the relay clicking in and out at or near the room temp when you change the setpoint?  If not, the unit may be defective.
Hunter Fan... | Answered on Nov 27, 2015
List of things to check:
Are the batteries good?
Is the system switch set to heat, and not cool?
Does the fan come on when you set the fan switch to ON?
If none of these things seem to be the problem, call hunter fan tech support at 1-888-830-1326
Hunter Fan... | Answered on Mar 13, 2015
usually this is a bad thermostat, no signal to furnace. have a great day!! if not the furnace its the thermostat not turning furnace blower on.
Hunter Fan... | Answered on Mar 04, 2015
Here's the online Manual Search page at Hunter Fans & Thermostats:
http://www.hunterfan.com/Support/Technical-Support/Parts-Manuals
See Page 8 of Manual Override programming for this thermostat:
http://www.hunterfan.com/SupportDocuments/OwnersManuals/44008-01Thermostat44668-44660WebR02102010.pdf
GL
Hunter Fan... | Answered on Mar 03, 2015
It could be, or it could be a wiring issue. Make sure that your wires are in the correct place (R or Rh and W), and that they are not touching each other. If you have the unit running, and you disconnect either of the wires, it should shut off. If it does not, then the problem is in the wiring. Hope this helps
Hunter Fan... | Answered on Jan 31, 2015
Just fixed mine;
Note the sensor channel on face of remote
(ref: http://www.manualslib.com/manual/257219/Hunter-44665.html)
Mine was set on Ch15, well the thermostat only monitors 14 channels had to flick down dip switch #1 to set Ch7.
Then on the base unit thermostat, see page 5 of a similar unit for 44668/44665 manual (below) then wait about 10 minutes for things to sync up, and press remote button to check sensor temp.
Note the button order for Remote Sensor Programming at base thermostat:
Hunter Fan... | Answered on Dec 30, 2014
You can get the manual at: http://www.manualslib.com/manual/257219/Hunter-44665.html
Normally these thermostats read remote temperatures but do not use them for control. The external remote sensor is normally put outside in our area yeilding an inside out side thermometer.
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
Hunter Fan... | Answered on Dec 08, 2014
Go to the website of the thermostat. You can download the owners and installation manuals there.
Hunter Fan... | Answered on Oct 10, 2014
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
344 questions posted
Top Hunter Dryers Experts
Joe Paxton
Level 1 Expert
Paul Bade
Marvin
Marvin
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hunter Dryers
  • Hunter Dryers
Most Popular Question
thermostat will not stay setting set
  • Dryers
