20 Most Recent Frigidaire FAS256R2A 25,000 BTU Window Air Conditioner with Electronic Controls Full-Function Remote... Questions & Answers
The compressor is being prematurely turned off. That explains why the cooling stops after a few moments. Either the thermostat is responsible or the electronics working with the therm are responsible for the anomaly.
Freon level is fine because it does cool when compressor is running. U might also want to check the start/run capacitor. That sucker starts the motor and keeps it running after the start. If the run section goes bad the motor will usually stop after it starts.
Frigidaire... | Answered on Aug 17, 2016
Amana makes a 17,000 BTU 115 Volt
Frigidaire... | Answered on Jun 09, 2011
Hi
look at your problem, very similar to the issue with my unit for a moment before.
Frigidaire... | Answered on Apr 26, 2011
It appears to have an electric heater core. See item #12 on the parts diagram
Frigidaire 12000 BTU AC & Heater Window Unit Heat Cool ...
https://www.ebay.com > ...
Find many great new & used options and get the best deals for Frigidaire 12000 BTU AC & Heater Window Unit Heat Cool FAZ12HR2A at the best online prices ... [PDF]
ROOM AIR CONDITIONER Model No. FAZ12HR2_PARTS
ftp.electrolux-na.com > prodinfo_pdf > edison
Jul 4, 2002 - M40L0004.eps FAZ12HR2A Parts.eps. 63611647.eps. Product No. FAZ12HR2A2. Series. Cool/Heat. Color white. Volts. 230/208. BTU-Cooling.
Frigidaire... | Answered on Nov 19, 2019
yes, but when it is running, does it also turn off??
Frigidaire... | Answered on Jul 26, 2019
Could have clipped the low voltage wire outside with a weed wacker, could have blown out the run capacitor or lost a major component! If the unit is buzzing when you turn it on but nothing's running (compressor or fan)then you have a failed run capacitor! The list of things it could be are endless without more info
Frigidaire... | Answered on Jul 13, 2019
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Frigidaire... | Answered on Apr 08, 2019
as long as it isnt leaking on your floor it should be fine
Frigidaire... | Answered on Oct 14, 2018
Are you sure you don't have a Heat Pump Condenser? You don't list the outdoor unit M#? If it is a Heat Pump system the outdoor unit has to run. Here is the link to the indoor unit. http://enora.nortekhvac.com/literature/a977a.pdf
Frigidaire... | Answered on Sep 11, 2018
with a meter you will need to verify motor is getting required voltage (high and low)Yes, its likely the motor but, do you put one in to see it still doesnt work?
Frigidaire... | Answered on Sep 07, 2018
if both are running you may be low on frreon, inspect for leaks before recharging.
Frigidaire... | Answered on Aug 10, 2018
Frigidaire FAS256R2A 25,000 BTU Window Air Conditioner with Electronic Controls Full-Function Remote... Logo
Popular Tags
5 questions posted
Top Frigidaire Heating & Cooling Experts
Bill Long
Pete Norton
Steve F
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Heating & Cooling
Most Popular Question
frigidaire ac starts cooling fine but
  • Heating & Cooling
