20 Most Recent
Maytag MDE9700AYM Electric Dryer Questions & Answers
Dryer will not start when I push the start
The buzzing is a good sign that the motor is bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
3/1/2015 3:01:33 AM •
Maytag...
Answered
on Mar 01, 2015
Will not heat
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101,./,./';
8/13/2011 12:28:38 AM •
Maytag...
Answered
on Aug 13, 2011
4 prone receptical in house,4 prone wire,3wire
As for the red and black of new cord connect on red and black on terminal block on back of dryer for the white it will have a brass link that connects from the white terminal on block to the dryer cabinet.remove that brass link attach the green wire to where the brass link attached to the cabinet and the white onto the terminal block
7/28/2011 10:15:55 PM •
Maytag...
Answered
on Jul 28, 2011
Dryer has power. controls light
Label each of the two (sometimes there are three) wires leading to the start switch so that you will be able to correctly reattach them later. Using caution, remove the wires. They are connected with the use of metal slip-on connectors. Grasp the connectors and pull firmly from the connectors. Do not pull on the wires themselves. You may need to use a pair of needle nose pliers to help you.
Use your ohmmeter to test your switch for continuity. Begin by setting your ohmmeter to measure resistance at a scale of R x 1. If yours is a two-wire switch, touch one tester probe to each of the switch's terminals. You should receive a reading of infinity. While the probes are still touching the switch's terminals, press in on and hold the switch. The reading should change to zero.
if it doesn't test like this, replace the switch
7/12/2011 8:39:47 PM •
Maytag...
Answered
on Jul 12, 2011
Dryer will not heat at all set in any selection
gas no heat tip....
check outthis
heatman101;';
6/30/2011 3:36:59 AM •
Maytag...
Answered
on Jun 30, 2011
