20 Most Recent
RIM BlackBerry 8100 HS-655 Bluetooth Headset HDW-12747-001 Wireless Headset Questions & Answers
Blackberry 8100 bluetooth pairing problem
after you have paired the two devices... the blackberry that is receiving the file has to be in receiving mode.
Go to MEDIA or music icon on your handheld where all of your tones are, hit the menu key and choose "receive using bluetooth" then hit send on the other handheld.
and there ya go !!!
its just another added security feature by RIM to avoid unwanted stuff being transferred .
Changing earpiece
•First take your device and hold it vertical.
•Looking at the earpiece that ressembles somewhat Alladin lamp, it's tip is positioned either at past 20 (for right ear) or before 20 (for left ear).
•Depending if it's one side or the other, you should turn the earpiece clockwise to 30 or counterclockwise to 30. So the "tip of the lamp", which is the ear channel of the earpiece in fact, is indeed at 30 past the hour.
•Then pull it out with a round motion downward, assuming the upper part is the blue light.
You can then change the side of the ear wire and or the earpiece for a different size supplied by RIM when you bought the device.
I don't know how/where to get new earpieces. They don't seem to sell them separately...which is rather frustrating considering the price they sell this device!
I have a PS3 and
Hi, All headset devices use a default code which 4 zeros,'0000'.
I guess that will do..
You can pass your comment..
Use this as a guide
Step 1: Set the headset to be discoverable
1. Turn off the headset.
2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Thanks for using fixya............
Remote funtions on LG HBS200 do not work with Blackberry Tour
When you go into the Tour's Bluetooth options, you can view which services are available for each paired device. Check the headset's properties and make sure all of the available services have a check mark next to them.
If that doesn't solve the problem, let me know and we'll try to find another solution.
