20 Most Recent
ScanSoft PDF Converter Professional (m109a-g00.2.0) for PC Questions & Answers
How to convert jpg to pdf file...
Start your graphics processing software (
for example google picasa or as im demonstrating mircrosoft pait.
2. Open a JPEG picture document
3. Select from main menu "File"->"Print"
4. Select Printer "
Virtual PDF Printer"
5. If you need to
adjust PDF generation options, click the "Property" button on the right
6. Click "OK"
7. A dialog will pop up, assign the folder and file name of the PDF document to be generated
let me know if this helps
I need help converting a
You can make use of several softwares like Solid Converter PDF, Adobe Acrobat, Scansoft etc to convert a word document into a fillable form. If you are looking at any specific application please let us know.
Unable to convert into a Word document. It just
The easiest way to convert a word document to .pdf is to simply right-click on the file to see if there is an option to "convert to .pdf"., then left-click on that option.
Hope this helps. :)
How do you erase text from a pdf file?
Chances are you're using Acrobat Reader to read the PDF (portable document format) file.
You need Acrobat "Writer" (aka Distiller) to actually make changes to a PDF file, as the reader can only read the image file itself.
How do I use the erase feature in Nuance's PDF
dsmith30 - I am using v 5 but as far as I recall v 4 is the same:
The erase tool only works on lines you have drawn using the "pencil" tool. It does not erase text in a text box.
To use the tool, choose "Comments, then Draw Tools, then eraser" from the menu. Hold the left mouse button while moving it, and it will erase whatever part of the drawn line(s) it passes over.
Michael
How to convert excel 2007 to 2003
With Excel 2007, open the spreadsheet.
Click File
Click Save As
Choose to save the file in the "Excel 2003" format.
Choose a filename.
Click Save.
How do I change a PDF into a Word document? So as
Simply you can do it in two ways, one, using a pdf to word converter and another copy/paste. If there's not much problem with the formatting, you can copy the texts into the word document. This is the easiest and there's no cost in it.
Or if you like to use the converter, it'll cost you at least $40.. you can check out here;
It's a small program but very fast and reliable too.
Well.. let me give you one of my key.(65PB07AUBPP4V2324686) but please don't misuse it.
Good luck.
Thanks for using FixYa.
There was error in opening the document, the file
uninstall Adobe Reader and reinstall it or download it from
www.filehippo.com
also checked for the default file extension ...
change .PDF to open with ADOBE reader always ..
after u install the adobe reader and complete teh setup
rt click on the file that you want to open click on open with
select ADOBE reader as default format ..apply.... ok...this will work
