20 Most Recent
GEH5450 Cordless Phone Questions & Answers
For change battery in the
Most phones have a connector witch only goes in one way, Thus there is basically a no need for +/- assignment.
You did not leave a model number so we can look it up so I would say this, the battery only goes in one way on most phone connectors and leave it at that,
good luck Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
I have a Model #
Hi!
Your battery is Nickel-metal hydride battery, a type of rechargeable battery 3.6v Ni-MH 2000mah. You should save these information should you need to purchase a need battery for your phone.
Cheers~
Musicaddict
I have a GE cord and cordless speaker model:
If you mean you'd like to add another handset to the base unit on this phone, I'm afraid you can't. This isn't a multi-handset phone and isn't expandable. If you want the kind of system that has the main base unit and several separate handsets, you'll have to start fresh with a new system. They aren't expensive.
I need a power cord
It is not just a power cord you need. Rather it is a power adapter that delivers 9Volts Direct Current and a maximum intensity of 450milliAmps.
It must also have the correct polarity.
My phone is programmed for
CHANGING LANGUAGE FROM SPANISH TO ENGLISH :
Hold the skip button done a few seconds and it should change back to english
TO CHANGE THE RING TONE:
There are 3 ring tones built into your phone.
To choose a ring tone, press FLASH followed by either 1, 2, or 3 when the phone is on-hook (phone is inactive, TALK light is off).
Please leave me comment, if you need furthr assistance
RNJ VINODKUMAR
How to set number of rings before answering
goto settings and select rings volume and choose the increasing or dereasing numbers, clue(the higher the is the increase of volume,while the lower the number is the decrease of volume)
Cordless telephone sw/from pulse to tone
In General Electric (GE):
TONE/PULSE DIALING
To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Radio shack phone c-4210
for my phone I hold down the flash key then the menu comes up and you can press * for tone or # for pulse. Hope it helps!
From Pulse to tone
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
