20 Most Recent
Samsung VP-DC161 DVD Camcorder Questions & Answers
Hi , i have got
Hi , Your going to have to Hard reset it , I believe if you hold down the power and play mode buttons at the same time it should kick in for you. Google it I had a similar issue with one of my cameras about a month ago but its all good. Just about ant device has a hard reset combination , good luck
When i plug my camcorder in to my tv, there is no picture
Unplug it! Sounds like you have plugged the video(yellow) into the sound input. Make sure that all the colours match the input colours. Yellow=Video White =Left channel Red=Right channel. Also make sure that the little silver 3.5mm jack is fully inserted into the camera. :)
Please help how can i download users manual for
To view the Operating Instructions try this link: Digital Cameras & Camcorder User ManualsOr, additionally could try in this for
SAMSUNG VP-DC161 - VPDC161Hope this helps and just keep in mind that your feedback is important
and I'll appreciate your time and consideration if you leave some
testimonial comment about this answer.Have a nice weekend. Thank you for using FixYa.Jose.
I have tried to finalise
Hi mark_carruth,
If the video is too long , then probably you would have to wait for quite a long time,
Therefore a better way is to shoot video at specific intervals , as it would create different files for each footage , so even if you lose one file , you have the others with you.
Now , in this case , I would advice you to please wait till the time you get the disc finalized and even if it's not finalized , and the disc has been written , then there is not much to worry as you might lose only a small part of the footage towards the end or ,you might not lose any part but the DVD might not work or be detected in PCs. It might be shown up as a blank one , which you know is not.
Hope this helps ..:)
To whom it may concern;
We
usually samsung camcorder have the firewire driver and firewire cable for you to transfer video file on the pc then burn it to the dvd or cd disk.try to go at samsung.com website
I have a samsung vp-dc171w mini dvd recorder. I
If your using DVD-RW make sure you format it in video mode. Do your recordings then when you want play them back on a dvd player you have to finalise the disk in the camcorder first.
If you want to continue recording you will have to un finalise the disk.
Viewing Discs on Samsung VP-DC161
RE; smasung DC 161(i) pal and possibly other models The reason why there is no disc message when there is definitely a disc is installed is because the disc programming has malfunctioned, Its because of Samsungs poor design, after powering up the camcorder and inserting a disc, the disc will load and a green flashing light appears for a minute or two while loading if the Samsung camcorder is switched off while loading the camcorder will essentailly self destruct and their is no remedy, however that does not mean the Samsung is completely useless,the camcorder can record on a 4 GB SDHC(max 4GB) card using the switch from disc to memory card
