20 Most Recent Whirlpool AD65USL / AD65USM Dehumidifier Questions & Answers
Bucket not filling, unit seems to be making more noise
If you are running and not pulling moisture first check air flow. Vacuum the front and back grills and make sure the coils are clean. If you have good air flow the cause of the problem is most like a sealed system issue. This is most commonly a refrigerant (freon) leak. check your use and care manual to find how long the warranty on the system is, sometimes it is as long as 5 years. If it is out of warranty then the repairs are more costly than a new unit.
7/24/2010 1:06:47 PM • Whirlpool... • Answered on Jul 24, 2010
Empty bucket light is on and dehumidifier will not run
The float switch for the condensate reservoir (bucket) is malfunctioning.
It's sending a false signal that the bucket is full.
Maybe just stuck and needs cleaning or it may have failed.
5/31/2009 1:37:24 PM • Whirlpool... • Answered on May 31, 2009
Unit trips out circuit after a few minutes (20Amp stand alone circuit)
make sure that the circuit breaker for the electrical plug is not faulty, cause after a long lifetime of high amperage flowing through it, the springs will start to get weak. If this is the case then you need to replace the electrial breaker. Otherwise, make sure that the power system on the system is not pulling too much current, Or that there is not a faulty breaker inside the printer itself, which has become weak.
11/5/2008 8:34:06 PM • Whirlpool... • Answered on Nov 05, 2008
My unit runs constantly
unit has a sealed system problem leak in one of the coils, a leak at the compressor, take it to an authorized whirlpool service servicer for a check
9/2/2008 4:21:07 PM • Whirlpool... • Answered on Sep 02, 2008
3answers
I have a Whirlpool Dehumidified (Model WDH70EAPW) and the readout for humidity is stuck on 35%, so it won't run.
You need a new humidistat. There are two here, but not sure if you your machine https://www.fix.com/parts/heating-and-cooling/dehumidifier/whirlpool/ There are numerous listings on Amazon, but all unavailable. https://www.amazon.ca/Kenmore-Whirlpool-WP1168670-Dehumidifier-Humidistat/dp/B077B1VZSV ..
11/19/2022 7:41:36 PM • Whirlpool... • Answered on Nov 19, 2022
Model AD50GUSB. Why doesn't fan operate?
1. Fan failure 2. Control board failure
8/20/2021 8:29:09 AM • Whirlpool... • Answered on Aug 20, 2021
Model AD5OGUSX. Where can I get operating instructions?
Try contacting Whirlpool to request.
11/30/2020 11:51:51 PM • Whirlpool... • Answered on Nov 30, 2020
Dehumidifier is not collecting water, fan working, compressor sounds like it working. I have Whirlpool AD50GUSX.
be careful. run your unit at the lowest setting for about 5 minutes, unplug it then try to touch the tubing. it should be very cold. if it is not cold then it needs to be serviced.
10/1/2019 9:44:22 PM • Whirlpool... • Answered on Oct 01, 2019
0answers
Whirlpool AD65USL / AD65USM Dehumidifier Logo
Popular Tags
4 questions posted
Top Whirlpool Dehumidifiers Experts
ZJ Limited
ZJ Limited
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dehumidifiers
Most Popular Question
bucket not filling unit seems making
  • Dehumidifiers
