20 Most Recent RCA 27F534T TV Questions & Answers
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
RCA 27F534T TV | Answered on Aug 31, 2016
You should try to see if the TV has a PC route and if it does then connect it.
RCA 27F534T TV | Answered on Mar 21, 2015
To select the inputs, you must have its remote control. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the sites by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
RCA 27F534T TV | Answered on Feb 05, 2014
Good day!!!!
Please follow this step of troubleshooting..
  1. Open the back cover.
  2. Check the B+ voltage of your TV.It should have at least 100vdc..
  3. Place the black test probe to the body ground of the TV..Then the red test probe is place it to the 2nd pin of the primary of ply-back..
RCA 27F534T TV | Answered on Sep 06, 2011
Hello
You can unlock your RCA tv by the folloing method. After unlocking it, you have to set a new parentioal control password.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
RCA 27F534T TV | Answered on Feb 27, 2011
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
RCA 27F534T TV | Answered on Oct 25, 2009
what you are looking for is the antenna button. this will change inputs
RCA 27F534T TV | Answered on Sep 06, 2009
i want to know who wants to sell me their rca t.v?
RCA 27F534T TV | Answered on Apr 13, 2009
you have to open the cabinet and inspect main board for bad solder connections or capacitors that not look good, of course be carefull handling it there are extreme voltages around this board. if not sure can handle the job contact a technician, but most problems are related to bad solder connections
RCA 27F534T TV | Answered on Mar 23, 2009
Here is something that I found that might help?
http://www.netnoise.com/boycott_rca/rcabook2007-8.html
This set was made before it was required to have digital tuning built in. You would need a digital converter box if you want off-the-air reception. (The federal program at www.dtv2009.gov that is giving $40 coupons toward purchasing a converter is out of money right now and is only putting people on a waiting list. It also looks like the changeover to digital is going to be delayed again, so you might not need to worry about it for a while longer.)
RCA 27F534T TV | Answered on Mar 14, 2009
RCA 27F534T TV | Answered on Jan 05, 2009
RCA 27F534T TV | Answered on Apr 30, 2008
RCA 27F534T TV Logo
32 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
manual rca 27f534t
  • Televison & Video
