20 Most Recent
HP Business Inkjet 1000 - Printer - colour - ink-jet - Legal - 1200 dpi x 1200 dpi - up to 23 ppm (m... Questions & Answers
Magenta Ink Cartridge Has Expired, showing this
If you only just purchased your cartridge I would suggest you return the cartridge for an exchange. Unfortunatelty when a cartridge has expired the date is set inside the cartridges chip and so far I have not come up with a way to get around it. You will need to replace the cartridge with a new one.
HP Inkjet 1000. I have installed 2 new
the printer is pretty much in a Freeze state.. so turn off the printer.. remove the power cords.. keep it out for atleast a minute and then reinsert the connections back and then try to turn on ur printer.. it will surely resolve ur issue..
My HP 1000 Photo Smart is not printing in color.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Printer works however NO INK on page all new
The new cartridges comes with seal wrapper on nozzle, have you remove it or not, if you have already remove it the reinstall the ink cartridges and try to print.
Regards
Ashly82
My notebook detect hp business inkjet 100 but i
have you installed the printer drivers ...... please install the driver first ...... post the comment if you are getting any error ....... if you installed the driver and still its not working please open the printer and faxes from the control panel and check your printer driver status ..it should be ready ....... please post your comment if you are getting any error ....so we can help you correctly ....
C8125-67033
Dear Sir,
Welcome to Fixya Expert zone
When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer.
Sometimes intermittent noises from the printer can be caused by the drive belt slipping over the gears. Clean and lubricat the bar with some silicon lubricant such as WD40 by spraying it on a paper towel and running it across the bar two or three times.
I think it solves your problem.If you have any problem regarding this issue leave a comment or feedback,we were happy to assist you.
Have a Nice Day
HP Business Ink-jet 1200
The pickup roller is problematic. First clean, then replace if necessary.
The part should be under $20.
To replace (from HP Support):
1. Unplug the power cord from the
printer, and allow the printer to
cool.
2. Open the toner cartridge door, and
remove the toner
cartridge.
3. Locate the pickup roller.
4. Release the small,
white tabs on
each side of the pickup roller by
pushing them away from the
roller,
and then rotate the pickup roller
toward the front.
5.
Gently pull the pickup roller up and
out.
6. Position the new pickup
roller in the
slot of the previous pickup roller.
Note Circular and
rectangular pegs on each
side prevent you from incorrectly
positioning the
pickup roller.
7. Rotate the top of the new pickup
roller into
position until the white
tabs on each side of the roller snap
the roller
into place.
8. Reinstall the toner cartridge, and
close the toner
cartridge door.
9. Plug the printer in to turn it back on.
Hope this helps.
