20 Most Recent
Gestetner DSm620d All-In-One Laser Printer Questions & Answers
Memory is full
call an expect to fix hard drive on the machine and this problem is over
6/6/2014 1:36:22 PM •
Gestetner...
Answered
on Jun 06, 2014
Add toner aficio mp 1900
open the front door of the machine.
remove the toner unit gently .
replace toner bottle.
refix the toner unit ans close the door .
wait for toner to load.
good luck..
6/6/2014 12:55:02 PM •
Gestetner...
Answered
on Jun 06, 2014
Code SC541 on machine
Replace the thermistors on the heating unit. There are 2, replace them both to avoid disappointment.
5/9/2014 1:16:17 PM •
Gestetner...
Answered
on May 09, 2014
I need to hook up
The Gestetner web site has several manuals for this machine that should help you to get the scanning working. Be sure it came with this capability. According to the product literature network scanning capability is an option.
7/18/2011 6:37:13 PM •
Gestetner...
Answered
on Jul 18, 2011
Ghost image of previous copies
the hot roller has gone
1 possibly u r not using manufactures toner if thats the case its 2 late anyways
2 u need to change it
there is a way of scraping it but ull need a service engineer to do it (temp fix at best)
11/4/2010 10:08:55 PM •
Gestetner...
Answered
on Nov 04, 2010
After installing an off brand cartridge for a
There are many different companies that sell compatible toner, and the quality varies greatly. You should try getting your money back from the company you bought that toner from, and find a new supplier if you can't get it from Gestetner. Premier is a company that sells compatible toner for many different machines, and they usually get pretty good reviews.
8/11/2010 10:03:20 PM •
Gestetner...
Answered
on Aug 11, 2010
THE SCANNER STOP WORKING AND
Hi. Please ping your DSM620D to see if the machine is connected to your network. Click "Start" then run CMD. On the DOS prompt, type "ping xxx.xxx.xxx.xxx" without the quotes then hit enter. Replace xxx with the actual IP address of your machine. Please let me know if you get successful result or not.
6/11/2010 2:55:09 AM •
Gestetner...
Answered
on Jun 11, 2010
Paper Jam - NOT
No you can't disconnect the sensor to continue printing.
Try opening the front and right doors and then close them.
Switch off and on again after 5 seconds.
If jam B still there, possible causes may be:
Exit sensor defective;
Exit sensor lever stucked;
Check the registration sensor/lever;
Rotate the registration roller with your hand slowly - there may be a piece of paper keeping the registartion sensor On.
Good luck and please rate me, thanks.
1/30/2009 10:03:13 PM •
Gestetner...
Answered
on Jan 30, 2009
Scanner
Check to see if the INTERFACE settings (press the 123 button select system settings and look for the interface tab) has an IP address that is set or whether it set to use DHCP.
The router change is almost certainly the reason why scan router in no longer working.
5/29/2008 9:40:44 PM •
Gestetner...
Answered
on May 29, 2008
How would I identify faulty fault sensors in gestetner MP2501L copier and replace them?
You can't. As I said you need the service engineer with the laptop. These Office Machines are NOT consumer serviceable. They hook up the laptop with the Ricoh software and it interrogates the computer, the mainboard and everything on it. The error message you get is from the brains inside it..Original question and answerhttps://www.fixya.com/support/t29802178-am_posting_again_stripped_off_gestetner..
Am posting again. I stripped off gestetner MP2501L 8 times due to problem ' see instructions on right side to solve' but same. No paper inside. What is the actual problem.
Hello Christopher
Are you in the Philippines? I notice that your copier has changed from Ricoh to Gestetner? We are a North American website.
This is a commercial office machine, and from my experience of them is that on the right side you will see on the inside, a list of instructions for where to check for obstructions. It seems you have already done this 8 times! Frustrating! Try this;
Open the right side cover, unlatch all the bits at that side.
Open the straight pass door on the left side.
remove ALL the paper drawers.
Get a powerful flashlight, look in all the spaces you have just created, especially at the edges of drawers and paper pathways. You are looking for a tiny piece of paper that one of your employees carelessly left behind after a paper jam.The one I found was right at the back of the straight pass door. When a sensor is covered, it creates that message.
If that fails, Ricoh will have to come and attach their Laptop scan software to it which will tell which sensor is obstructed or has failed.
