20 Most Recent Philips 20PF5121 20 in. EDTV-Ready LCD Television Questions & Answers
yes it is not fixable.
Philips 20PF5121... | Answered on Aug 01, 2011
Im not familiar with your T.V byt you can get a universal remote control for that just go to electronic store then ask if they have a universal remote for your T.V make sure you memorize your T.V brand and model..
Philips 20PF5121... | Answered on Jul 14, 2011
This is most certainly a capacitor in the power supply that has gone low in value, hence a low startup supply rail voltage. I would be looking in this area. Tell tail signs of faulty capacitors are from their tops bulging up with possible brown liquid discharge, or if their plastic base inserts give first with the pressure, these pop out from the can.
Philips 20PF5121... | Answered on Feb 13, 2010
if the tv accepts 640 x 480 via DVI lead in safe mode, then as long as the tv is set to work in conjunction with the same resolution as your pc by the pc to DVI setting, it must be your pc's graphics driver that is the problem, as in safe mode the graphics vga driver only is loaded and not the advanced graphics options and resolutions, so enabling you to view on an external monitor. You should be able to right click on your desktop, then graphics properties and select either clone/dual or monitor. If this option does not show then you need to go into your graphics cards properties and ensure that an external screen or multiple display; is enabled, depending on your graphics driver.
Philips 20PF5121... | Answered on Jul 22, 2007
https://translate.google.com/translate?sl=auto&tl=es&u=https%3A%2F%2Ffactory-reset.com%2Fwiki%2FPhilips_Service_Menu
Cuidado cambiando algo que puede ruinarlo completamente.
https://www.usa.philips.com/c-p/55PFL5706_F7/140cm-55-inch-class-full-hd-1080p-digital-tv/support/
Empuja Online chat para chatear en ingles.
Philips... | Answered on Dec 04, 2019
ASK GOOGLE I HAVE NO CLUE WHAT YOU WANT WITH YOUR POOR SPELLING
Philips... | Answered on Nov 29, 2019
Ring manufacturer and ask for code. Sylvania ??? hmmm
Philips... | Answered on Nov 25, 2019
try to unlock your dvd player to play all free region. what you need is the code to unlock and a remote control to enter the into menu/programming mode. please specify model # of your dvd player when you look for the unlock key.
Philips... | Answered on Nov 22, 2019
With a video cable.
Do you have a question? Then tell us what model of TV and what device you are trying to connect to it.
Philips... | Answered on Nov 21, 2019
it could be defective lamps which are big project to find the right parts & replace
Philips... | Answered on Nov 14, 2019
the dvd are not from your country region thats what it means to retify re burn the dvds to your country region code or buy a multi region code dvd player
Philips... | Answered on Nov 07, 2019
Philips 20PF5121 20 in. EDTV-Ready LCD Television Logo
7 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips 20pf5121 58 problem very long
  • Televison & Video
