20 Most Recent
LG 50PX4D 50 in. Plasma Television Questions & Answers
27lcdb03b does not turn on
Check to assure snug plug in on the back. If you have pets especially cats they can get in behind and tug on cord or chew them. If all is well (check batteries in remote). You can try an universal remote, switch is gone (which I doubt) and none of these are the issues than you a a "cold solder"
No standby light
No standby light means not power function. Its SMPS power supply section has the fault. It should be replaced. If you wish to get more details,
check this site. Pull up older posts there.
I have a 50 inch
Hi there
Try doing a system reset on the TV, by unplugging everything from it, then wait 3 minutes and plug the power lead in only. If it works, then plug everything back in one by one. If the problem persists it may be that the software has been corrupted in an update process, which can be performed at night via the aerial signal (this may be why it was turning on at night). In which case contact the TV manufacturer.
Hope this helps
TV_Doctor
Keeps blowing up
Sounds like a factory issue. You should call lG directly and explain it to them. They're likely to get you another unit.
Geno
