20 Most Recent
Konka DLC-3211UT 32 in. LCD Television Questions & Answers
Sound won't work
HI:
This is maybe due to a faulty main board or cable box. If you are on a cable try unpluging it from the AC outlet and waiting 2 mins, this will cause the cable box to reboot. If this does not work then you might have main system board that needs replacing.
My Konka KLC-1508U was working fine, last week, I
hello!the problem is not on the power cord it is on the backlight of your tv (a cold cathode lamp)this needs to be replace you can reach the cathode lamp by disassembling the screen/monitor of your tv the lamp is place at the top and bottom of the screen be very careful when doing this.replacement is available online at shopjimmy.com.
sometimes the problem is on the inverterboard the inverterboard is the one supplying a current to the lamp the input voltage of the inverterboard is 24v so you have to check the input voltage from the power supply to the inverter board.a poor solder from the terminal post of the power supply to the inverterboard will also cause the problem.so resolder them.reminder..always unplug the tv before working on it..goodluck!A four thumbs up is much appreciated for answering your free question..
No picture
1. This sound like the Video inverter is gone or the ( for the layman) the light tube. This needs replacement.
This is common on most LCD screens . the inverter is connected to a luminous tube ( high luminous florescent tube) which excites the LCD crystal which give you visual at a very fast scan rate. The inverters can go due to not enough heat dissipation in the cabinet. The LCD TV generates quite a bit of heat in the slim cabinets.
Sometime the voltage and current generated from the power supply to the inverter will degrade due to a faulty component.
Need tv codes
codes are:
0906, 0702, 0203, 0306, 0208, 0911, 0842, 0942, 0504
one of these should work
Remote doesn't work
There is a website (remotes.com) that sells replacement remotes for Konka TVs. Their tollfree number is 1-800-REMOTES.
By typing in "TV Repair Near You" into the Google searchbox, you will find a website that tells you the locations of local repair shops, by typing in your Zipcode.
How to unlock konka tv key lock?
I would check the batteries position in the remote. Usually one points up, the other points down. If both are placed in the same direction, they cancel each other out. That could drain the batteries too. If Up/Down doesn't work, try Down/Up. Good Luck.
