20 Most Recent
HP Compaq ProLiant DL360 G4 Server Questions & Answers
I was given a HP
why use a servere
its not designed for gaming at all..
sure free. but ?
so this software loads from maker ok?
and the device manager is clear of ALL ERRORS> in the stack
no yellow, no red marks no missing drivers? there?
Geforce 8400 Graphics card
3/8/2017 3:40:34 PM •
HP Compaq...
Answered
on Mar 08, 2017
Trying to download norton 3560
You can download a 30 day trial version of Norton 360 version 5 from the link www.norton.com/n360s_5 Once the installation is complete, you can activate the program with the product key if you have one. Regards,Muhaim
6/8/2011 2:56:50 AM •
HP Compaq...
Answered
on Jun 08, 2011
64 bit os vmware esxi
make sure that the Ubuntu is seeing an X386 and not a X686 emulated processor. Ubuntu stopped support on 686 procs for the 64bit family awhile back. you can choose this under the items.
7/11/2010 5:19:44 AM •
HP Compaq...
Answered
on Jul 11, 2010
How to booting safe mode in HP DL360 G3 server
As soon as the server turns on and you see a BIOS screen press the F8 key constantly. This should be you to the safe mode screen. If not then try another keyboard, or another USB slot.
11/12/2009 7:16:45 PM •
HP Compaq...
Answered
on Nov 12, 2009
Dl360G4 Accelerator board battery will not hold a charge
Check your firmware levels and make sure they are current. When you download the latest firmware from itrc.hp.com, take a look at the history/change log in between your version and the current version and see what was fixed. It may shed some light on this problem.
6/8/2009 7:36:22 PM •
HP Compaq...
Answered
on Jun 08, 2009
How do I fix window 10 to listen audio mp3 cd
NO PC told at all and posted to Proliant server forum
that is no PC and as such the OS is not allowed there w10 nor does it have sound chips, at all, its a server running in huge dark, no humans server farm..... so let me guess you posted to wrong forum
and never told PC model sure.
so windows sounds work in the test in control panel
yes !
the, MP3 is complex, it can be from high data rate, source
and will not play unless converted .
one thing to try is use this free app
called Audacity
https://www.audacityteam.org/
then play it or convert it
or buy a USB sound dac that can decode any sound file on earth
or learn to test you PC first
windows sounds work
then in google type
simple MP3 sound test
https://file-examples.com/index.php/sample-audio-files/sample-mp3-download/
works good above so your MP3 is no good or wrong bit rate.
if fails yours only , buy new DAC USB dongle now it plays them all
if windows sounds are dead the sound driver is missing
or on a server there is no sound chips oops. buy the DAC dongle.
if only 1 MP3 fails out of 100's find a better one or buy a DAC.
Reset bios putty
You need to be specific about the exact model of server that you're using. Features of the various generations of the HP iLO are accessed in different ways.
BE SPECIFIC.
Blinking red light and beep sound coming from the front blade Slot 1.
That drive has failed, is it set up with a RAID configuration? Do you have the Dell monitoring software installed? Is it set up with Hot Plug drives? If so replacing the drive with a new one will start the RAID rebuild. Otherwise one way to turn off the bleep is to reboot and go into the RAID controller configuration
Front blade Slot 1
It Indicating something Faulty, if you have something plugged in, remove, and reconnect, If unable to find, check device manager or event log for details, that should have some info.
No servers, cant get mail or send mail cp was
If you lost everything then you've obviously reloaded all your software for the server, now you need to load your daily backup tapes onto the server so you can have mail again. you will also need to know all of your DNS's and you MX records if you're running exchange and if you don't know how to do any of it, then my suggestion is to hire a network administrator and it'll cost between $1k - $1.5k by time he's done bringing your system back online.
