20 Most Recent
Dell Latitude C600 Notebook Questions & Answers
PASSWORD AUTHENTICATION SYSTEM DELL LATITUD C600,
if it is the bios password, you will have to remove the cmos battery and get it reset. Howeever,if it is window login in password, in that case you can simply insert the disk and start installing. it will do a parallel installation automatically.
How do i reset toshiba c600
Hi,When you say reset I will assume you want to reset to factory defaults? Meaning like as when you first bought it. There are a number of ways to do this. If you have the original installation and driver disks that came with the laptop you would use those to reinstall the operating system and other software. On some laptop models they partition a portion of the hard drive to be a recovery partition which can be used to restore the laptop to its original state. To do this, you would want to look for a program that is installed on the computer that will launch this recovery action. It may be titled "Toshiba Recovery Program" or something similar. If the laptop is under warranty support you can contact Toshiba to have them walk you through this process, being an additional option. -G33k
Got of ebay and its
Youll Have to Contact the Seller And get the Passwords. Otherwise You'll have to wipe the harddrive and reinstall Windows to get rid of it
Can i use a ddr ram in a dell latitude c600
hi simply NO this is sdram as here are the specs for this laptop
Memory
Architecture
SDRAM
Memory module sockets
two user accessible SODIMM sockets
Memory module capacities and type
64-, 128-, and 256-MB
3.3-V SDRAM SODIMMS 1
Standard RAM
64-MB memory module
Maximum RAM
512 MB
Memory clock speed
100 MHz
Memory access time
CL2 or CL3 (Note: CL3 indicates a CAS latency of 3 clocks)
BIOS address
F000:0000-F000:FFFF
hope this helps
How do i remove the hard drive from my latitude
Turn the computer off.
Close the lid.
Disconnect the AC power.
Remove the battery.
Flip it over.
Undo the screws that hold the cover over the disk-drive.
Remove (or slide-out) the disk-drive.
How do i turn on
Hi, you haven't said what operating system you have; but try going to control button after clicking the start button. In control panal select your wifi and configure from here. Hope this helps.
Dell latitude wont read 256 megs of ram
The c600 can handle up to 512MB of RAM, so it's likely one of your RAM sticks is bad or not seated correctly. Are you using two 128MB sticks? Remove the stick from the second slot and turn on the computer with only one stick installed, and see if the RAM is recognized. Then take that RAM out and try the computer with only the other RAM stick -- if either is not recognized, that stick is bad.
If both are recognized, try reinstalling both RAM sticks and see if the computer will recognize them. If not, make sure they are both seated properly. You may have a problem with the second RAM slot if it is still not recognized. If you have access to other RAM, try that too and see if it is recognized.
Computer is very slow how can i speed it up?
If you are using Windows XP, use the following steps to disable some startup programs:
Click Start-> Run
Type msconfig and press Enter
Click on the Startup tab
Click Disable All
Click Services tab
Click on the checkbox Hide all Microsoft services
Click Disable All
Click Apply and Close
Restart the computer.
You will get a notification about using the system configuration utility.
Click the checkbox for Do not show this again
Click Ok
If the system appears to run faster, the next step will be to re-enable a few items under startup tab. You can keep most of the items disabled except your antivirus software.
