20 Most Recent Whirlpool 24 in. GU1200XT Built-in Dishwasher Questions & Answers
My kic dishwasher does not switch heater on. If I manually make the pneumatic switch the heater does come on
TEST THE heating elements and thermost 2) Timer: test for defective,repair wires broken, loose, or burn, clean contact. God bless you 5_10_2012_10_53_24_am.gif5_10_2012_10_53_35_am.gif5_10_2012_10_53_46_am.gif
5/10/2012 10:54:13 AM • Whirlpool 24 in.... • Answered on May 10, 2012
Whirpool GU1200XT is having problems
Your problem is the timer can be stuck. cleant the contact for corroded, tight the wires for burn, loose, or broke. finaly can be defective. 2) Heating elements and thermostast defective, test see how test. God bless you 5_9_2012_3_57_45_pm.gif
5/9/2012 3:58:04 PM • Whirlpool 24 in.... • Answered on May 09, 2012
I have a whirlpool GU1200 dishwasher. There is a
Hello....My name is Keith.....Please give me one moment while I bring up the parts drawings, and then I will start to address the issue.
Thank You....
3/8/2011 7:39:06 PM • Whirlpool 24 in.... • Answered on Mar 08, 2011
Leaves food residue on dishes, mostly glasses and
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
2/27/2011 7:31:37 PM • Whirlpool 24 in.... • Answered on Feb 27, 2011
There is no start button,
No on button! Look for a slideswitch, or rocker switch, or a dial switch and turn it clockwise to desired setting. If none of these is present, refer to users manual, or call customer service (800) # that is usually on the door. Good luck, best regards.
2/3/2011 2:04:51 AM • Whirlpool 24 in.... • Answered on Feb 03, 2011
The dishwasher makes quite a loud sound, not
It could be a motor with bad bearings. But to check you need to remove washer and take outside or in garage. Put machine on it's "back" and take pump apart and look for obstruction. If you are mechanically inclined this is EZ!
1/3/2011 4:25:30 PM • Whirlpool 24 in.... • Answered on Jan 03, 2011
What is the minimum times a week that the
To keep the gaskets and other rubber componats from drying out run it once a week, It's also a good idea to run your garbage disposal while the dishwasher is running about once a week.
12/30/2010 5:48:21 PM • Whirlpool 24 in.... • Answered on Dec 30, 2010
Clean light blinks. It blinks
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishawasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
11/30/2010 3:09:37 PM • Whirlpool 24 in.... • Answered on Nov 30, 2010
It is stuck between cycles. How do i reset?
Have you tried turning the mains power off and on after a short delay?
If this does not work then press the following buttons in quick succession (about 5 sec) and when all lights light up press Cancel.
HIGH TEMP SCRUB, AIR DRY, HIGH TEMP SCRUB, AIR DRY
10/22/2010 9:50:32 PM • Whirlpool 24 in.... • Answered on Oct 22, 2010
2answers
Dishes in top rack don't clean
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
8/30/2010 9:52:50 PM • Whirlpool 24 in.... • Answered on Aug 30, 2010
When dishwasher is turned on to the cycle mode -
The impeller on the wash pump is worn out or the disposer screen is obstructed. Disassemble as needed to investigate the cause.
5/28/2010 9:10:31 PM • Whirlpool 24 in.... • Answered on May 28, 2010
Keeps on filling with water when turned off
water in let valve
5/2/2010 8:16:07 AM • Whirlpool 24 in.... • Answered on May 02, 2010
4answers
Whirlpool Dishwasher No Power: GU1200XT dishwasher
The thermal fuse protects the entire dishwasher circuit from overload. Not just the heater or motor, but everything. From the diagram in the tech sheet, you can see that this fuse is between the incoming line voltage and the door switch. This means it is controlling all power to the dishwasher. Any shorted component can open the fuse
You will get two new wires with the fuse kit.
You need to make sure you use the new wires in the kit with the new fuse.The old wires have a bad connection that create heat and blow the old fuse
And in this link you can download Step by step instructions on how to install the 8193761 Thermal Cutoff in a whirlpool made dishwasher
http://appliancejunk.com/forums/index.php?PHPSESSID=91c1fcf39918e187862c23ad23666b45&action=downloads;sa=view;id=54
RNJ VINOD KUMAR
4/16/2010 5:35:00 PM • Whirlpool 24 in.... • Answered on Apr 16, 2010
Whirlpool 24 in. GU1200XT Built-in Dishwasher Logo
63 questions posted
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
whirlpool gu1200 dishwasher
  • Dishwashers
