20 Most Recent ASUS M2N-MX Motherboard Questions & Answers
2answers
I have done a monitor upgrade i.e, DELL S2340L
Unless you are using a high end motherboard with the latest chipset, you will find it very difficult to get an "onboard" graphics chip to output that resolution. And your motherboard just doesn't have the power to display at that resolution. You will need to find a graphics card that will display that kind of resolution. The Nvidia GTX 650 or the Radeaon 7750 are both capable of handling that display and are cheap (in terms of graphics cards anyway).
7/23/2022 7:35:25 AM • ASUS M2N-MX... • Answered on Jul 23, 2022
2answers
I can't burn dvd"s on my dvd writer
Please uninstall the burning application & reinstall it after your pc restarts. then try to burn dvd's.
best regards,
Krishan
5/8/2019 2:31:35 AM • ASUS M2N-MX... • Answered on May 08, 2019
Creative 5.1 Speaket not working in window 7
1) Right click the volume icon located in your bottom right hand corner of your screen. 2) Click "Sounds" 3) Highlight your default speaker device 4) Click "Configure" From there, you should be able to select what kind of sound system you have installed on your laptop or PC (ie 5.1, 7.1 etc.) Click "Apply" to save system changes. If that doesn't correct the problem, check to see if your sound card is supported or is compatible with Windows 7
2/3/2018 12:05:43 PM • ASUS M2N-MX... • Answered on Feb 03, 2018
I have bought acme wireless
Try the manufacturer's website for a driver.
1/22/2018 5:08:53 AM • ASUS M2N-MX... • Answered on Jan 22, 2018
I've got an asus m2n-x plus motherboard and i'm
You'd be wasting money
1/2/2018 8:13:00 PM • ASUS M2N-MX... • Answered on Jan 02, 2018
My cpu is not shutting down even i shut down. But
Shut down by holding in Power button for 5 secs... press F8 continuously on start up, go into Safe Mode with Networking.. have a look around at some of the Devices in Device Manager, check Drivers, also default to normal mode in Bios/Uefi
9/3/2017 1:27:22 PM • ASUS M2N-MX... • Answered on Sep 03, 2017
4answers
How can I install Windows 8 on my computer with M2N MX SE motherboard?
Hello try the asus homepage here:http://support.asus.com/Download.aspx?SLanguage=en&m=M2N-MX&p=1&s=24The vista drivers should work, when you install windows 7 again.The files has to be unziped, before you install the driver.But that does not mean the drivers will work on win 8.Here are the other models of the mainboard:http://support.asus.com/Download/ModelList.aspx?SLanguage=en&keyword=M2N-MX&type=1Consider to buy a new mainboard, that supports win 8.A new mainboard cost around 100 dollars, and the cpu aswell.You maybe have to buy new ram, because all new mainboards have ddr3 ram.Good luck
12/25/2015 6:42:15 AM • ASUS M2N-MX... • Answered on Dec 25, 2015
ASUS M2N-MX Motherboard lan driver PHY 10/100 lan driver
Visit the following link. https://www.asus.com/Motherboards/M2NMX_SE/HelpDesk_Download/ From OS drop down menu, select the operating system, download the LAN Driver and enjoy.
10/24/2015 9:03:00 PM • ASUS M2N-MX... • Answered on Oct 24, 2015
5answers
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
5/10/2015 2:34:25 AM • ASUS M2N-MX... • Answered on May 10, 2015
2answers
It was just this morning when I tried to turn my
Try replacing the power supply - I had a similar problem that was fixed that way. If that doesn't work, it's probably the motherboard itself. The CPU is also possible - have you overclocked it or otherwise cooked it? Is the CPU cooler/fan blocked with fluff, or has the fan been slow (or stopped) - noisy fan is a sign of bearing stiffness/partial seizure which slows the fan and lets the CPU get too hot. If the CPU is fried, you get the symptoms you describe (MB won't start the PS)
2/1/2015 7:24:03 AM • ASUS M2N-MX... • Answered on Feb 01, 2015
2answers
No sound on headphones
Increase the volume label, from your head fone if the system have.
If there is no sound install the audio driver ,
You can download the driversfrom ASUS WEB site. http://usa.asus.com/index.aspx So please go there website For download copy bellow thelink and paste on address bar. http://support.asus.com/download/download.aspx?SLanguage=en-usSuppose, you need driver for, ASUS K8V-VM
Product =Mother Board So Series= (Socket NO.eg. 754 etc.) So Model= (Model no will be K8v-vm) And please select the O.S (XP / VISTA/ WINDOWS 7) version of the drivers that matches your P.C and search. Now you can download easilyone after one. after download all the driver ,unzip the fie with winrar or zip. Download the winrar free, copy the link and paste onaddress bar. http://www.filehippo.com/search?q=winrar Install it . Now right click on everydownloaded file and select EXTRACRT TO THE FILE FOR......,then create a newfolder with the with the driver file, you can install easily. Hope this helps.
1/24/2015 12:16:37 PM • ASUS M2N-MX... • Answered on Jan 24, 2015
2answers
No display
BE MOORE DETAILED.
1/5/2015 4:42:33 AM • ASUS M2N-MX... • Answered on Jan 05, 2015
2answers
Hard disk adata classic ch91
Call geek squad at Best Buy, but probably it is trashed, toss it and buy something else
10/7/2014 12:07:31 PM • ASUS M2N-MX... • Answered on Oct 07, 2014
6answers
BIOS 1004 cpu not support
I got it :-)
Damn Asus , it was a hard session ;-)
1. Make an ISO from your original Asus CD denn insert (with isobuster or something) the Bios Firmware 1004 in the main Dir name the file M2N-MX.ROM
2.Burn a Second disc with the 0804 Bios ROM also rename the 0804 Rom to M2N-MX.ROM
3. Go to EZ FLASH with ALT + F2 and then insert the 1004 CD wait till Erasing is ready Then Turn OFF your PC :-) so you crashed the bios thats what you need to run the embeded CrashFRee Tool
4 After you turn your PC on insert the 0804 CD then it flashes the this Rom and we are Happy :-)
mfg Eddi Hope this helps someone
8/14/2014 12:10:17 PM • ASUS M2N-MX... • Answered on Aug 14, 2014
WhyI have no sound on win7 with asus m2n-mx motherboard???
https:/t/downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18355&lang=eng From the specs of your motherboard it uses a sound max audio device to do sound and I am not sure but this might be a driver that will work for you for windows7 I would say windows 7 has loaded a generic driver that doesn't quite work
8/13/2014 2:25:49 PM • ASUS M2N-MX... • Answered on Aug 13, 2014
0answers
I am using an amd a8 series...can anyone tell me
no do not think so
5/19/2014 4:59:10 PM • ASUS M2N-MX... • Answered on May 19, 2014
579 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
lan driver phy 10 100 lan driver
  • Computers & Internet
