20 Most Recent
Roxio Easy Media Creator 7 Questions & Answers
File images
There is no need to convert iso. Better you go to select file and select all the avi file you need to write on the CD/DVD. The files will be transferred on your disc.
Roxio burning dvd
I think it will not. The output has a different file name. But don't save the converted file same as the source file. Or you could try experimenting with it using a short avi file then convert it to dvd.
Also are you making its output be automatically burn unto the disc? It will keep its original file.
Have Roxio 7 and want to install it on Windows Vista
Easy Media Creator 7 is not supported on Vista. Easy Media Creator 9 and above are only supported. Anything lower may be able to go onto Vista, but Tech Support is not going to be able to assist you if you have problems.
Easy Media Creator 9 Suite re-install problem
Look carefully at your disk and check for any scratches or fingerprints. There are ways to clean scratches to make a CD work again, using creamy peanut butter and a soft napkin or cloth, for example (but be sure to not follow the circular 'grooves'---wipe from center to edge or vice versa, and remove all traces of peanut butter before reinserting it into your computer!)
How to uninstall sony sound forge 10?
Depends what OS system you are on. But most windows OS have Control Panel. If you click that you will see an option to install software. Click that and wait for the Sony software to show up in the list of software. Then click it and follow the instructions.
How do i uninstall roxio easy media creator 7
Go to start button, control panel, uninstall programs under the programs catergory. Find the Roxio program you want to uninstall. Click on it and click uninstall at the top of the window. That will start the uninstall wizard. Follow the prompts to uninstall. You may need to restart your computer afterwards.
Keeps asking for blank dvd
check roxio configuration the check if it is using the right drive.
sometimes the burner programs try to burn discs in virtual drives.
After I install Roxio 7
Can you please tell any error it is specifically showing or just saying as error occurred.?
Thank You
Certificate File is missing in roxio
The following steps will completely remove any Roxio and Sonic software from your computer.
- Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
Creater 7 will not record dvd or cds
If you are getting an error "No dvd/cd drive detected", you need to delete the roxio certificate.
Goto C:\program data\, find the roxio or sonic folder and delete it and restart the computer.
Regards,
Shrey
Can't hear sound when capturing vhs home videos
click on start then control panel then click on audio devices and sounds check your audio taskbar to see what is selected for your audio output device. Select the amplifier associated with the tuner card. Also, right click on the speaker in the bottom right hand side of your screen in your taskbar and then select adjust audio properties. When all of the slide bars, see if your tuner volume is listed. if it is not, left click properties and see if it is listed there. if it is but not checked then check it. now go back and it just the volume for it.
When trying to use dvd
Hi!
To fix your problem, you'll have to update your graphics adapter driver.
Please specify your graphics adapter model if you need more assistance in that matter.
Alternatively, follow these steps:
1. Open the program.
2. Go to Tools -> Options -> Graphic Test
3. When it finishes, click OK.
4. Close and restart the program.
It's recommended to follow those steps even if updating the driver solved your problem.
Good luck,
Pelu.
Computer does not recognize the usb
I am not sure what your program has to do with your USB drive. what system are you running?. You may need to uninstall the USB port in device manager and restart your pc and let windows detect it.
